11-06-2009, 04:13 PM
You can also jack the front up by putting your jack right behind the front wheel on the frame and while you're jacking it up listen for an unnatural sound as you're going up. Then let it drop down quickly (obviously you don't remove the wheel) and listen for a noise. Repeat on the other side, then do the same for the rear.
