Old 11-07-2009, 05:53 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Maintenance on most of these cars is really not that differant than any other car you won. Do you check the oil on your DD every time you fill the tank? Do you check tire pressure that often? Do you change the oil that often?
Unless you're really running it hard, or use a solid lifter cam, maintenance is pretty much the same as a Ford, Dodge, or Chevy with the same equipment.
