Thread: new owner
Old 11-08-2009, 06:08 AM
hartprods hartprods is offline
Cobra Make, Engine: factory five, 460ci
ok, pin fixed, oil pressure seemed to be oil pump, high performance one gave out...have stock one in and working fine...now..starting problems...cold cranks fine ( with new stock strter vs the Summit he had in there)....runs for a while ( as in heats up )....HARD crank if any...this is a 460...i put new ground strap on yesterday, cleaned up ground lead on battery..battery good...dont want to buy new alt ( orielly meter says its bad ) if its something else...also put heat wraps on stater yesterday also...anyone have this problem ? and what was solution ?....
thanks to all of your support by the way....
i REALLY want to come to a gathering and see what you guys think on a lot of matters with her....take care.
sh
