Old 11-08-2009, 07:16 AM
Mooch's Avatar
Mooch Mooch is offline
Cobra Make, Engine: ERA 427 - #783
Originally Posted by bobcowan View Post
You're exactly right, and that's why I qualified it with, "the same as a Ford, Dodge, or Chevy with the same equipment."
If you use a good modern synthetic oil, why change it every 3K miles? If you use a new tire and wheel, why worry about the pressure so much? If you use a closed coolant recovery system, you won't loose any coolant.
Partly it depends on how you build it, and what parts and systems you use. And partly it depends on how you drive it. I'd bet most Cobra's would do perfectly well with changing the oil once a year.
Like I said it the beginning, intervals will never be agreed upon.
I do agree that many Cobras would be happy with a once a year oil change, but would I? I will admit that I change the synthetic oil in my daily driver every 10k miles. It is a modern engine made for daily use at moderate driving.
Just the engine I'm putting into my Cobra will cost about half of my daily driver. It will be driven hard and will be stressed every time it is driven. So I'm going to do frequent changes. Will it make any difference to the engine? It's debatable. Even if I know it makes no difference, I'll still do it. The placebo effect to my conscience is worth it.
To make it easier I'm doing some things.
1: Top-side oil changes with a Mityvac. The remote filter is easily accessible. It takes me ~10 minutes to do an oil change. Every third change will be traditional through the pan.
2: Rare earth magnets, pulled from old hard drives, on the remote oil filter. poor man's version of: http://www.shopfiltermag.com/ This should catch the bulk of small metal in the oil for when I do the top side changes, and the drain plug on the third change should get the rest.
Mooch
ERA Registry Map
If you have an ERA and want to be listed, contact me with your info and I'll put it up. The minimum info I need is chassis number and location. The rest is up to you. The most information needed would be: chassis number, body type, city, name, CC nickname, and email address.
