All you got to do is disconnect your ignition and crank until you see your
oil pressure gauge start to blip up a bit (less than 10 seconds). Then reconnect your ignition, pump your accelerator pedal to the floor twice, and it will fire right up. I do it every Spring after it has been sleeping since Thanksgiving. Pulling the distributor to spin the
oil pump is overkill -- don't bother.
