Old 11-08-2009, 11:44 AM
Gunner's Avatar
Gunner Gunner is offline
Cobra Make, Engine: ERA 707, 446ci FE
Originally Posted by mikeforte View Post
I use this custom grind camshaft on smaller engines with fantastic results.
The cam is the key to almost any engine, SBFs in particular. The way to build an engine is to select all your other parts and then custom-grind the cam to suit them and the intended use. Barring luck, any other approach is going to lead to compromises and performance that's off the desired curve. A custom cam, spec'ed by an experienced builder, is so cheap compared to the alternatives...
= Si Opus Quadratum vis, angulos praecidere noli. =
