Thread: On the scales
Old 11-08-2009, 06:49 PM
dcdoug's Avatar
dcdoug dcdoug is offline
Doug, as a general rule, the front tires on our cars are going to have a couple of pounds more than the rear. One way you can get a feel for the best pressure is by using a pyrometer to measure the temps on the inside, middle, and outside of your tires. You then adjust the pressure so the middle temp is as close to the other two as possible.
I adjusted the tire pressure today to more like 26-27 in the rear and 28-29 in the front (the pressure is exact in all tires, but I am not sure of the completely cold temp as I drove about 1/2 mile to the gas station before filling them, so they might have been warmed up slightly - will check again when they are cold). Slightly rougher ride, but the car handles much better. I think that was it. I will get the cross weights done at some point on the CACC scales too just to be sure, but it's much better now.
www.partskeeper.com
