Old 11-09-2009, 08:11 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
The oil temp sensor tube can be put through in different places on the car; in front of the driver or more towards the center of the car, sounds like yours is in front of the driver. that "hydraulic clutch hose" may actually be the oil pressure hose from the block to the oil pressure gauge??? If it is the standard plastic hose, you should have no problem. If it has been replaced with a braided hose, you have more work ahead of you. There is also a cable that goes to the clutch. Hopefully the little slot will give you the room you need. Be VERY CAREFUL to use large sweeping bends in the new sensor tube, not tight bends, and be sure to keep it as far as possible from any spark plug wires because one spark to it can put a small hole in the tube and the gas inside will escape giving another broken gauge. PM me if you need more info, I have a file somewhere about an alternate tube routing...
SPFWiringDiagrams@Comcast.net
