Old 11-09-2009, 01:30 PM
DAVID GAGNARD's Avatar
Originally Posted by khansmith View Post
What is the best way to manually fill the bowls?
Take a quart bottle like the ones you get rear end oil in or just any quart plastic oil bottle with the cap that you cut the tip off...... fill half full with gas and put the top on and use a length (10 inches or so will do) small clear plasitc tubing attached to t he top and fill the bowls thru the vent tubes,only takes a few seconds and works like a charm.............
David
DAVID GAGNARD
