Thread: tranny id
Old 12-09-2001, 09:05 AM
David Kee David Kee is offline
The tag tells everything. Maybe we can figure out what it is with more information. Get the casting numbers off of the maincase and tailhousing, see if the input is 1 1/16" or 1 3/8", see if the output is 28 or 31 spline, if it has a 1 1/16" input shaft remove the lid and count the teeth on second gear . Also measure the tip of the input shaft to see if it is 1 1/8" or 3/4" long. Tell what you find and I'll tell you what you have.
