Old 11-09-2009, 06:45 PM
*13*'s Avatar
*13* *13* is offline
If you keep the water temp at 160 for a few minutes does it close? If the engine is constantly producing heat you want the thermostat to allow enough flow to keep the coolant at an optimum temp. The thermostat may need to be open "a little" to do that. Where do you have your temp unit mounted? What reading are you getting running down the freeway?
ERA FIA 2088
