Old 11-09-2009, 08:56 PM
madmaxx madmaxx is offline
I agree. I may pull the temp sending unit out, get a pan of boiling water and monitor the water in the pan temp and gauge reading as the water cools. The only problem with temp guns is if the emissivity value is not set correctly you reading can be off 30F.
Originally Posted by *13* View Post
Do you know anyone with a temp gun that can read your engine temp? ...so that you don't need to change parts out to test that they are operating correctly?
something like this?
http://www.ohiopowertool.com/p-2178-...y-2277-21.aspx
