Old 11-10-2009, 10:19 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by Silverback51 View Post
Not the best picture, but it's something that was on my computer at work.
You can see that the lexan piece is in place in this photo. It's moved slightly to the side so I got a little cooling with it in place.
Like I said, it fits in the gap between the body and the cooler. Since there is room at the top, I just slip it in the upper gap, and then let it drop down.
Hope that helps.
That helps. If a CSX car has the same set-up, then I will go that route. I think my oil cooler might be set a bit farther back, but I'll check it out.
www.partskeeper.com
