Go Back   Club Cobra > Club Forums > AC Cobra
February 2026
Old 07-29-2003, 06:32 PM
Default Old engine questions
Folks,
First, thanks for the welcome, I appreciate it!
I'm looking to pick up an engine lift and stand, and I need to know- what's a typical weight of a 302 freshly pulled from a doner?
Also, what's the best way to clean up that freshly pulled old dirty engine (manifold, covers, block, pan, various alum parts, etc.) so it sparkles like new and is then befitting of my "pending" build? (Assume a comprehensive overhaul, so everything's coming off.) I'm sure there are pro shops that will do a bangup job, but what about the more economical DIY method?
Thanks!
Art
Old 08-02-2003, 06:27 PM
Art,
Sorry for the lack of reply's! I personally don't know because I didn't go down that road. Maybe a little direction for folks will help like is this a Factory 5?
Come on guys, help Art out!
BTW, I frequent Big Canoe a couple times a year - my mother has some land up there - georgous place!
Old 08-03-2003, 08:40 AM
ENTDOC's Avatar
Art,check out Harbor Freight for the stand and lift or buy used;these items do not need to be the best as when you are finished they are just in the way.I would find someone to steam clean the motor first ,then take home and disassemble.This will get rid of the worst grime without messing up your driveway and should only cost 20 -30 dollars.chuck
Old 08-03-2003, 08:41 AM
ENTDOC's Avatar
also the weight of the 302 should be around 300 lbs no problem for a 1 ton lift. chuck
Old 08-03-2003, 10:00 AM
GeorgiaSnake's Avatar
Cobra Make, Engine: Sold - Unique FIA - SA 396 Stroker
Art I assume you have a donor car that you will pull stuff from. If that's the case and it runs why not start with the car wash down in Jasper. Drive it down, spray it with a couple of cans of Gunk and blast away.
Randy
Sold the Unique - Bought a Porsche TT - Sold the TT - Bought a truck
Old 08-03-2003, 12:48 PM
Junket's Avatar
Cobra Make, Engine: shell valley
Art what works for me I put a add in the local classified (The Nickel) then do the same to same rid when I am done about the clean procession after the motor is out on the stand set the hole thing on a old blanket (don't have to clean up the grease spots)I liberated from the wife and go at it with a couple cans of Gunk and a stiff brush.Don't forget the eye protection.
Best of luck on the project Ken
Talent is your head in communication with your balls.
Old 08-03-2003, 04:21 PM
All right! Thanks guys, I do appreciate it. Sounds like pretty basic stuff, nu mystery to it.
