Go Back   Club Cobra > Club Forums > AC Cobra
Old 04-24-2004, 01:44 PM
Default HELP!BAD ROD KNOCK INS Stock 302
developed in the coupe this am on the way to a car show. What should I replace when I tear the engine down to make a good reliable small block on a budget (working on 4 car and 2 boat projects at this time-this was not budgeted for!)
Shoiud I add a mild cam and do some head work wor a little boost?
Who should I use for the engine work" Southern Automotive?
All suggestions/opinons apprecuated. cb
Old 04-24-2004, 07:13 PM
Johan's Avatar
Default Re: HELP!BAD ROD KNOCK INS Stock 302
Originally posted by Chiperb
HELP!BAD ROD KNOCK
All suggestions/opinons apprecuated. cb [/b]
typical gear head
Blows his motor and now wants a cam and head work. Chip, sorry for your misfortune.
Old 04-24-2004, 07:17 PM
And one week before the Mitty! Was all reay to show it off! And the roadster is down needeing another brake master: poor me!!! See you next weekend in something! cb
Old 04-25-2004, 12:53 AM
You got a lot going on it sounds like. SO,, why not just do the minimum to your engine for now? Like if the crank and rod aren't damaged maybe you can just put in some bearings on the bottom end and let it go? Won't have to pull the heads, pistons, etc that way. Later do the whole thing, heads, cam all that.
Guess it depends on how bad a rod knock your talking about.
Old 04-25-2004, 05:58 AM
EXCELLENT IDEA!!!!! Have THE big Historic Race next weekend and want to "show off" the coupe. Thaks fopr the idea-gonna go out and putt the panright now
ps: what s rod knock anyway" the con rod slapping against the crank??? cb
