Go Back   Club Cobra > General Discussion > Advertisers Forum
Old 10-02-2010, 01:36 PM
Jerry Clayton's Avatar
You might want to consider a larger stem sodium filled exhaust valve---that skinny stem doesn't have a lot of material with that hollow stem and of course not much strength when hot( over 1000 degrees)
Old 10-02-2010, 03:17 PM
undy's Avatar
Most are going to stainless with no loss in RPM capabilities.
Too many toys?? never!
Old 10-02-2010, 03:42 PM
Your talking about rpm or breaking off of the valve head???
Old 10-02-2010, 04:07 PM
undy's Avatar
Both, the stainless valve is much less prone to breakage and a good quality light weight valve like Ferra's offerings won't decrease the engine's abilty to spool quickly, attain design max RPM and over stress the springs @ 7K.
Old 10-02-2010, 07:36 PM
The stainless valve is not less prone to breakage just cause it is stainless---there are one piece, 2 piece and 3 piece valves----there has always been a big flap about one piece valves while in reality most are 3 piece----head spun welded to stem and a hardened tip--a one piece is very expensive as it is formed out of a big piece of bar stock or a very complicated forging process to make the head big on the end of a small diameter rod---
The sodium filled, hollow stem valves transfer the heat better to the guide so the head actually stays cooler and won't burn as bad. Going to say a 11/32 hollow stem/sodium filled with the necked down pro flow type head probably would be a better choice for a high heat engine.
Of course injecting some wator methonal mix thru the cylinder on the overlap could cool the head and valves-----
Old 10-28-2010, 09:49 AM
Quick update...
Ran into a little snag with the new Comp camshaft. The journals were .0008-.0009" over factory spec for an LS cam and it had .0015" runout on the center journal. Long story short, it wouldn't go in the block. (Yes, I eliminated the possibility of a bad cam bearing install by sliding a stock cam in....it went in as smooth as silk.)
Comp is making right on it....but it put a temporary pause in the mock up.
