Go Back   Club Cobra > General Discussion > Advertisers Forum
Old 08-11-2011, 07:17 AM
Default Complete 390FE Engine, Quicktime, TKO 600 Package, Under $12500
Ok, get it all in one spot. Complete 390FE engine, with billet steel flywheel, RAM clutch kit, Quicktime bellhousing, Tremec TKO 600 transmission, etc. Bellhousing is dialed in, clutch kit installed, engine dyno'd, everything ready to rock and roll.
Included:
*Ford 390 Production Block, Fully Machined
*Ford 390 Crankshaft
*Scat Forged H-Beam Rods
*Keith Black or Probe Pistons
*Hastings Rings
*Clevite Bearings
*Comp Cams Hydraulic Roller Camshaft
*Morel Lifters
*Comp Cams Timing Set
*New Balancer Spacer
*Professional Products Balancer
*Melling Oil Pump
*Moroso Oil Pan/Pickup
*Water Pump
*Duraspark Distributor
*Edelbrock FE Heads
*PRW Rocker Arms
*Edelbrock Performer RPM Intake
*Ford Racing Valve Covers
*Quick Fuel Carb
*Pulleys/Brackets
*PRW Billet Steel Flywheel
*Quicktime Bellhousing
*RAM Clutch Kit
*McLeod Clutch Fork
*Tremec TKO 600 Transmission
*Engine Dyno'd
*Bellhousing Dialed In
*Clutch/Bellhousing Assembled
*Plugs/Wires/PCV Valve/Breathers
$12400
If a more budget engine was desired, we can do this package with reconditioned FE rods and top the engine off with a set of production C4AE-G cylinder heads.
This would be a very nice drop in package, making 450hp and a ton of torque at very streetable rpms.
Old 08-11-2011, 11:32 PM
fordracing65's Avatar
How do you make a profit at this price.
PRIDEnJOY
Old 08-15-2011, 01:10 PM
mkassab's Avatar
Cobra Make, Engine: Unique 427 S/C, 427ci
My guess.... Low Overhead and a passion for what he does.
Mark
Unique 427 S/C, B2 Motorsports 427ci SBF, TKO600, Jag IRS 3.73 Posi, Avon Tires.... and so much more http://www.uniquecobra.com/forums/forumdisplay.php?f=68
