Go Back   Club Cobra > General Discussion > Advertisers Forum
Old 04-06-2014, 04:02 PM
Cobra Make, Engine: Backdraft
Default HELP needed with my backdraft cobra!!!
I drag race my backdraft cobra and I have a serious problem with the rear differential getting loose and breaking the grade 8 lower bolt that holds it in place. When it breaks we have to use a point chisel to remove the broke bolt. I am looking at the solid mounts that backdraft sells and going to switch them out to solid. I am afraid to use lock tite cause then I won't be able to remove the broke bolt. I have been tighting the bolts every time I race but it is not enough. Please I need some advise here. Thank you
Old 04-06-2014, 04:23 PM
Mark Brye's Avatar
If my memory is correct the older cars had a 12mm bolt. They later went to a 14mm bolt. Do you know which you have?
Seems like a couple years ago I saw someone post about an upgrade for this. Was a kit that was used on the E36's that worked on our cars. Will see if I can find it.
Old 04-06-2014, 04:25 PM
I have he later 14 mm bolt My production number is #990
Old 04-06-2014, 04:27 PM
Mark Brye's Avatar
Installed differential support kit...great results!
Try the link above.
Old 04-06-2014, 04:32 PM
Mine already has the 14 mm bolt. Will this kit help me more?
Old 04-06-2014, 04:39 PM
Mark Brye's Avatar
The OP seemed to think it helped. I have never seen the kit in person or have any experience with it. Just thought I would post it as an option. I think there were a couple other people that used this. Try doing in search in the Backdraft section, I think this subject has been talked about a couple times.
Old 04-06-2014, 04:44 PM
Thank you
Old 04-06-2014, 09:06 PM
Cashburn's Avatar
Backdraft Racing Dealer
You need solid diff and cage mounts if you are dragging. What engine do you have? What tires? Sometimes a softer bolt is better as they are less brittle.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 04-06-2014, 09:17 PM
Small block 427 and 335 wide tires
Old 04-06-2014, 09:19 PM
Is the solid Differential mounts what you are pertaining to? Backdraft part. Backdraft Parts - Solid Diff Mountings - Performance Suspension - Suspension - Products
Old 04-06-2014, 09:21 PM
And is the cage you are talking about is it like this one Active Autowerke BMW Differential Support Bracket E36
Old 04-07-2014, 05:55 AM
Cashburn's Avatar
Yes on these.
VINTAGE MOTORSPORTS
Old 04-07-2014, 05:57 AM
Cashburn's Avatar
No on this. I am referring to these:
Rear Subframe Bushings/Mount Set - Turner Solid Race - E36, E36 M3 - Turner Motorsport
Or
Backdraft Parts - Solid Sub frame bushings - Performance Suspension - Suspension - Products
VINTAGE MOTORSPORTS
