| 29 |
10-28-2009, 01:24 PM
AK
Cobra Make, Engine: TBD
How safe is your roll bar?
For those of you who don't check Jalopnik daily...
Here is a warning for all of us who like to drive "briskly"
No fear, neither the driver nor his passenger were injured, amazingly!
http://jalopnik.com/5390934/mustang-...over-tire-wall
Notice the bolt-in rollbar punched through the floor with the bolt plate and bolts showing. (see photo 8 full size)
Notice the roof and rollbar together did little to protect the people.
Now, how do you get out of the inverted car? Doors won't open.
Add a little leaking fuel and hot engine parts....
Not a good way to go.
I think they crawled out through the trunk after the car was turned back over.
Bolt in roll bars are "Style Bars" if they are bolted to the floor pan. Even the rear bracing will do nothing if the vertical bars give.
Now, how would your car do in a similar situation. Or more important, how would your head do? The very tiny footprint of a single hoop bar impacting dirt with the weight of the car on it will sink in to some degree. The Mustang had already lost all its speed before flopping on the roof as you can see it didn't slide.
Wear a helmet. Pad your rollbar. Drive carefully.
Enjoy life, it is priceless!
ATTITUDE =
The difference between
Ordeal and Adventure
James
10-28-2009, 02:05 PM
Fra
Cobra Make, Engine: Paint:Metalflakes Royal and Abalone stripes registered in France in 1973. Engine: Ford Shelby aluminium block, 482; two 4-barrels 600cfm Holley; Edelbrock Performer Aluminium heads,,fluid damper,4-speeds Aluminium Toploader (short), 2.88rear
I alsolutely do not care about the safety of my roll bar. I have one only because I must look officially legal for racing.
Queenie
10-28-2009, 02:21 PM
wa
It's hard to tell for sure, but by one picture it appears that the car did not have a cage. It was a single hoop bar. Not a good situation for a full size car.
John Hall
10-28-2009, 02:52 PM
Look at pic #1. Click on the "Full Size" link under the pic. It has a four point roll bar but as the first post mentions, it punched through the floor in pic #8. Simply not a good roll bar install from the get-go.
10-28-2009, 03:45 PM
wa
I still think I'm right. When I look at picture 1, I do not see any cage structure running down the A pillar. And in picture 8, the only thing I see punched through the floor is the hoop. Nothing up front.
John Hall
10-28-2009, 06:59 PM
Ca.
Who was the "official" that inspected that car?
he shouldnt have been on the track to begin with.........
Mi
Silverback51,
I have to agree, that is NO cage. A simple 4-point "mail order" from Jegs or Summit maybe, but no way is it a "cage". Point 1 as mentioned, no A-pillar bar, point B no horizontal side bar from front to back, C no diagonal bars for either side. Nothing showing through the rest of the car bottom. If there was a cage it had to be the weakest cage possible!
DV
10-28-2009, 07:29 PM
I've run at Hallet a few times and this is one of the most difficult tracks to run on!!!!!!!!!!!!! Not a good place for a novice to learn on!!!!!!!!!!
looks like a simple/el-cheapo hoop behind the driver, with maybe 2 bars running to the rear, definetly bolt in and not bolted-in correctly......Not even close to anything a car like this should have in it!!!!!!!!!! This type of car should have nothing less than a professional 8 pt. cage in it..........
DAVID GAGNARD
10-28-2009, 07:45 PM
Evryday is a roadstr day
Oh
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
Bet there are some sponsors out there that are wishing they hadn't signed on to this project.....
 aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment"....  ...from Will Rogers
10-28-2009, 08:25 PM
VIC
I was reading the comments below the article
nice to know that spontaneous outbreaks of Python can still be relied upon.
LoBelly
10-28-2009, 09:22 PM
I like the last pic with the bumper sticker "look better, go faster" ...it should read "look better, brake sooner"
10-28-2009, 09:32 PM
GA
The bar surely did not do it's job. But it also looks as if the tire barrier is what launched the car, not being high enough. Bet that got changed.
Ralphy
10-29-2009, 03:34 AM
Agreed. Nothing up front. Thought you were implying a two point bar.
10-29-2009, 05:11 AM
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Agreed, It did not have a proper cage. Even a mild steel full cage would have supported this car no problem. I run a heavily modified 69 Mustang Pro-Street Drag car. A full cage is a must. I have the whole car tied together. Can't skimp on safety.
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
10-29-2009, 01:13 PM
I wonder if the installer had extra parts once he was done. Maybe some 4"x4" mounting plates or brackets to tie into the B-piller area. ...jacka$$
10-29-2009, 05:53 PM
AK
Autopower
In the article feature of his Mustang it lists an Autopower Rollbar.
Probably the first one on the Autopower Page: http://www.autopowerindustries.com/rollbars.asp
The "Street Roll Bar"
Or perhaps the "STREET-SPORT ROLL BAR" as they say designed for street use.
Since he lists harnesses in his description, the street-sport would give him attachment points.
Notice how TINY the base plates are! Real strong guys.
Nothing to bolt to the side sills for strength either.
And! the main hoop (er, only hoop) is PRE-BENT for you! I am sure the side bends are to give more interior room for the seats but I can just see those as the weak points that allowed the bar to bend as it was punching through the floor.
Scary "Roll Bar" in any case. Don't trust your head to this!
ATTITUDE =
James
