Old 01-06-2010, 08:52 AM
Default Center of gravity
I'm looking for the Cobras approximate center of gravity height for some suspension calculations. Doesn't matter if it's from an original car or a kit.
Any ideas?
Simon
Old 01-06-2010, 09:16 AM
Gunner's Avatar
Cobra Make, Engine: ERA 707, 446ci FE
Purely an educated guess, but I'd place it at about 12 inches from the ground, plus one, minus two.
I would be surprised if it's above the hub line of most examples.
= Si Opus Quadratum vis, angulos praecidere noli. =
Old 01-07-2010, 06:53 AM
CG height seems to be 16.5" for the FFR spec racer, just found it on the internet. I also had expected it to be a bit lower like in the 12-14" range.
I also found an interesting way of measuring it: http://home.earthlink.net/~whshope/id31.html
This is another tabular approach:
http://home.earthlink.net/~whshope/id39.html
Old 01-07-2010, 07:21 AM
Jerry Clayton's Avatar
two rules of thumb on cg----camshaft centerline, belly button height
Old 01-07-2010, 08:36 AM
Gunner's Avatar
Cobras have so little weight above the engine centerline that it seems 16 inches is much too high. But as I said, mine is only an eddicated guess. Maybe fat driver heads pull the CG up?
Old 01-07-2010, 08:58 AM
Looking at all the components in my 3D layout, I'd estimate our chassis with suspension, plus the engine and trans is about 14.5"-15". Add the body (~24") and other miscellaneous and I wouldn't be surprised to end up with over 16".
Old 01-08-2010, 10:56 AM
snakebittexan's Avatar
Cobra Make, Engine: BackDraft, Keith Craft 408; 1967 GT500CR
Check out the enclosed link;
http://www.circletrack.com/chassiste...oll_angle.html
CONSTANT CHANGE IS HERE TO STAY.
Old 01-09-2010, 08:36 AM
I will get a suitable scale and give the tilting method a try.
Originally Posted by snakebittexan View Post
Thanks for posting, this is some interesting stuff!
