Old 01-24-2010, 09:34 PM
Cobra Make, Engine: Contemporary, 427 SO
Default Tool for installing braided line fittings
I read a post approximately 2 months ago describing a great tool for installing fittings to braided line. It is a great tool and the people that used it indicated that it was easy to use and very good quality. I tried a search and was unsucessful. Anyone have the this info?
Len
Old 01-24-2010, 09:43 PM
Cobra Make, Engine: HI-TECH 289 FIA
Here you go Len
http://www.koultools.com/
Summit has them for sure, maybe Vic Hubbard or Morgans
fiaroadster
Old 01-24-2010, 11:23 PM
Rwillia4's Avatar
Don't do SS lines without them!! it is not worth the cut and slices.
Old 01-24-2010, 11:59 PM
Cobra Make, Engine: Kirkham 592
I have never actually needed anything. I grease everything before assembly and do fairly well. I also tape the ss with electrical tabe and cut it with a 3 inch abrasive wheel
Old 01-25-2010, 06:36 AM
One word of caution ..... especially if you use a hacksaw ( 32 tooth or finer ) or an abrasive cutoff saw to cut the hose ..... clean it , clean it and then clean it again ! Don`t assume that because the hose is new , it`s clean inside . You would be surprised at the crud that can get inside a piece of hose and you sure don`t want that in your engine . The Koul tool really works well as I used that on my project . Wish I had one when I was doing field service work for Parker .
Old 01-25-2010, 07:02 AM
Ron61's Avatar
I use about the same approach but I have various sizes of short steel rods that I stick in the end of the hose to hold it firm. Once the cutting is done, I then blow it out with my compressor.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 01-25-2010, 07:23 AM
DonC's Avatar
I've used the Koul Tool and compared to the manual method it wins hands down particularly if you're going to be doing more that a couple of fittings. You still have to use a little bit of care in cutting the lines since anything has limits but by and large a very useful tool.
DonC
Old 01-25-2010, 09:37 AM
fkemmerer's Avatar
Cobra Make, Engine: ERA, FE BBF
I think that you are think of the tools made by Koul Tools? Check out the following post for some additional information:
Anyone put together their own steel braided lines?
- Fred
Old 01-25-2010, 11:27 AM
khansmith's Avatar
Cobra Make, Engine: Hurricane Motorsports, Southern Automotive 428 FE
I did almost all of my lines by hand and I decided to by koul tools when I was doing some rework. I felt like an idiot...why didn't I buy this tool before? I will never make another braided steel hose without this tool.
Hurricane Motorsports: HM1046
Follow the build on my blog: http://khansmith.blogspot.com/
1974 Pantera resurrection blog:http://1974pantera.blogspot.com/
Old 01-25-2010, 11:40 AM
DAVID GAGNARD's Avatar
This is all I use, works like a charm,bends the stainless mesh over the edge of the rubber hose for easy instalation, quick,easy,cheap and it works.............
http://www.speedwaymotors.com/Heavy-...tter,5299.html
DAVID GAGNARD
Old 01-25-2010, 01:52 PM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Ditto. Cuts are nice and clean. Very easy to use and not very expensive. Got mine from Summit. $35.95
http://www.summitracing.com/parts/SUM-900040/
Old 01-25-2010, 02:07 PM
jwd's Avatar
jwd jwd is offline
Same here. It only takes a minute to do a fitting. No special tools needed.
Old 01-25-2010, 04:12 PM
roadrod2000's Avatar
Cobra Make, Engine: Unique 289 FIA HiPo 289 with Shelby dual quad intake
If you are still cutting the hose with some type of saw check this out http://www.anplumbing.com/installation.html I have done this several times and it works perfectly everytime.
Old 01-27-2010, 03:25 AM
TButtrick's Avatar
wow! never seen that technique. thanks for posting.
