Old 01-26-2010, 10:01 PM
Garage10's Avatar
Cobra Make, Engine: west Coast Cobra FRP 460, Tremec 5 sp, Ford 9" rear
Default west coast cobras in Knoxville,tn
I am looking for any west coast cobra owners in Knoxville, Tennesse area as that is where the Lokar cable manufacturer is located. I have a wcc and would like to convert to a lokar throttle pedal and cable system but they (lokar) can't recommend one without seeing an actual WCC. Can anyone out there help me ?
Thank You
Brent
Brent
Get in,buckle up,hang on and scream all you want cause nobody's gonna hear you over the sidepipes!
Old 11-27-2010, 06:56 PM
Xack's Avatar
Cobra Make, Engine: West Coast Dreams
Default Lokar is a good choice
This post was done almost a year ago. But I have .02 cents worth to spare.
The item WCC sells you is a push pedal cable. I promptly replaced it with a Lokar pull cable and the chrome steel gas pedal mounted to the vertical firewall in the foot box. I aranged the lever to pull the cable down, vertically and not through the firewall. The cable goes up and throught the fiberglass above the frame and behind the engine. This is a pull type with springs will keep the throttle from being stuck wide open like WCC's design may do.
Good Luck,
Old 12-15-2010, 03:54 AM
Default Pedal
Do you happen to know the part number of the Lokar assembly you used?
