Old 05-01-2010, 11:31 AM
Default Fram warning
This is about the Fram HPGC-1 FUEL filter-not oil.
Just bought a fresh one as I change it out every 2nd season. The new one says 'Made in Turkey' -not sure where the 2008 one was made. Well the Turks (wish Turk was still on here ) can't follow engineering drawings any better than the Chinese, Indians, Mexs' or any non-US suppliers.
The stamped recess in each end of the cartridge which receives the rubber sealing washer is smaller by maybe .020" than the 2008 model. The result is the supplied washers are too big for the recess in the new cartridge. You can't get a good seal which is dangerous for leaks.
Amazingly, the OLD washers fit the new cartridge perfectly-maybe because they soaked in gas for 2 seasons. Since they were in perfect condition I used those on the new filter and it closed up securely.
Just a heads up to users to be sure you have a gas-tight seal.
Here's the filter I'm talking about:
Chas.
Old 05-01-2010, 11:33 AM
Tommy's Avatar
Thanks for the heads up. .... Are those copper fuel lines?
Tommy
Previously owned EM Cobra
Old 05-01-2010, 01:15 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
The copper jumped out at me too. You really need to change them to something made for gasoline. Copper is for water. You might think it is better than rubber, but I think it gets brittle and would need replacing at some point.
Old 05-01-2010, 02:06 PM
Yes, copper. I had tried stainless but couldn't get the bend radius because it's so stiff. I used stainless on the fuel log feed line with much softer radius bends.
Been replaced twice since '96. Inspected carefully each time and they were perfect when removed. Pliable still after use and no cracks.
Thanks for the concern.
Chas.
Old 05-01-2010, 06:23 PM
jwd's Avatar
jwd jwd is offline
Get rid of that copper line. There's a reason why it isn't approved for fuel line use and has NEVER been approved for use with any manufacturer. It will crack with any vibration. Hope you have good insurance, if they cover you for such a blatant error (some don't). Do it right or don't do it.
Old 05-01-2010, 06:39 PM
Gatorac's Avatar
Cobra Make, Engine: BDR 930, 427 Windsor T56
I've seen a car on fire from using copper.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
Old 05-01-2010, 07:07 PM
Silverback51's Avatar
It is pliable, but it will fatigue and then crack.
John Hall
Old 05-01-2010, 07:33 PM
If copper cracking from vibration is the issue, why is a copper line suitable for the pressure line for the oil pressure gauge?
Old 05-01-2010, 07:36 PM
Jerry Clayton's Avatar
Do I see teflon tape on some inverted flare fittings????
Old 05-01-2010, 07:38 PM
Most lines on oil pressure guages will have a loop to absorb the vibration/work hardening.Remember that years ago we didn't have some of these more modern materials
Old 05-01-2010, 07:49 PM
jwd's Avatar
jwd jwd is offline
Don't know what to tell you. The original oil pressure lines on Corvettes are NOT copper. They are steel. Maybe Ford had another of one those "great ideas" Honestly, never seen any ORIGINAL lines made of copper anywhere in the auto industry, but I've only been restoring cars for 40 years (Fords included).
Jim
Old 05-01-2010, 08:01 PM
I thought Corvettes had oil pressure lines that were OEM copper plated steel. Anyway, any truth to this post on vetteweb?
http://www.vetteweb.com/tech/vemp_09.../photo_13.html
Old 05-01-2010, 08:11 PM
jwd's Avatar
jwd jwd is offline
Some were copper plated steel, some were galvanized plated steel, but none were pure copper because of the problems associated with it.
Only a fool would use one for a fuel line.
Old 05-01-2010, 08:14 PM
In that post on the VetteWeb the tech quote was: "Luckily, copper oil-pressure-line kits are available from most auto-parts stores. The copper line will be less likely to leak, and if pinched will seal itself rather than spewing hot oil onto the driver and passenger." Any truth to that?
Old 05-01-2010, 08:17 PM
jwd's Avatar
jwd jwd is offline
I can't say one way or another. One thing for sure, they NEVER came from the factory that way.
https://www.paragoncorvette.com/p-35...sure-line.aspx
Old 05-01-2010, 08:20 PM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
some were copper plated steel, some were galvanized plated steel, but none were pure copper because of the problems associated with it.
ouch!!!!!
Old 05-01-2010, 08:23 PM
Originally Posted by cdnus View Post
ouch!!!!!
I dunno... in my experience ol' ERAChas tends to be pretty handy with his Cobra repairs.
Old 05-01-2010, 08:26 PM
jwd's Avatar
jwd jwd is offline
That may be true BUT, in this case, he's wrong to use copper fuel lines. I seriously doubt that anyone who knows anything about cars would argue this point.
Old 05-01-2010, 08:30 PM
... and the fact that they are used all the time for fuel lines in boats?
Old 05-01-2010, 08:39 PM
jwd's Avatar
jwd jwd is offline
Years ago I used to race off-shore boats and I've never seen copper fuel lines on any boats I've inspected. Not to say they weren't any. Just never seen them. The big thing on boat inspections were compatible fuel hoses and an approved check valve at the tank. Regardless, use whatever you want. It is common knowledge about the inherent copper lines.
