Old 05-26-2010, 09:49 AM
Default Mechanical Fuel Pump Install.
Getting the mechanical fuel pump off of my Roush motor is easy. Two bolts, pops right off. However, when trying to reinstall it, I was unable to compress the lever on the fuel pump that follows the eccentric on the camshaft so that I could line it up and install the two hold down bolts. I must have just removed it when the lever was fully compressed on the high point of the lobe.
Did I just happen to remove it whent he rod was fully compressed thus making it hard to reinstall?
Should I turn the motor over till the low point of the cam is even with the lever? What is the trick. I never had this problem with a fuel pump before.
Old 05-26-2010, 10:34 AM
DAVID GAGNARD's Avatar
Dats the way I do it, bump the motor over till it goes in easy and bolt it back up.........
DAVID GAGNARD
Old 05-26-2010, 10:42 AM
Best way to bump it? Remote starter? Or with the key?
Old 05-26-2010, 10:58 AM
Depends, when I alone in the shop I use a remote starter bumpy thingy, when the wifey or someone else is there, I get them to sit in the car and bump it with the key while I try to get the fuel pump in.....Either way will work fine......
DAVID GAGNARD
Old 05-26-2010, 11:12 AM
Thanks, will use the remote.
Wifey would let the engine start.
Old 05-26-2010, 11:19 AM
Got the Bug's Avatar
You can turn the engine over with the coil wire removed...no need to worry about it firing up.
Doug
