December 2025
Old 05-30-2010, 04:49 PM
JST4FUN's Avatar
Cobra Make, Engine: SOLD-SPO2660, Southern Automotive 406FE, TKO-600
Default Lifting using a floor jack
This one may be simple, is there any problem using a floor jack positioned at the weight midpoint to raise the entire side at one time? The SPF book shows the entire frame as possible jacking points. I have access to a lift, but not here at home! Since I'm dealing with a fiberglass body, I don't want to get it wrong!!
Thanks!
Joe
Have fun and enjoy life, because when it is over, it is too late!
Old 05-30-2010, 04:54 PM
jwoodard's Avatar
Thumbs up
I don't think there is an issue. In fact, I recall a promotional clip, showing doing just what you are talking about, to show how rigid a SPF frame is, and still allowing the doors to open and close without any binding or interference from frame flex. I'd say go for it!
Jim Woodard
Old 05-30-2010, 05:22 PM
Silverback51's Avatar
I have a SPF, and I always jack it up from the side.
Position the jack right at the transition point of the frame. This is approximately where the front of the door is.
John Hall
Old 05-30-2010, 09:30 PM
JST4FUN's Avatar
Thanks, you guys confirmed my initial thought! I'll proceed accordingly!!
Joe
Old 05-30-2010, 09:37 PM
terry251's Avatar
Cobra Make, Engine: SPF Roadster, 418W
I'm curious. Should you open both doors before adding weight to the jack? Seems that would prevent any untoward binding on the doors.
Terry
Old 05-30-2010, 11:01 PM
SMOKNAC's Avatar
Cobra Make, Engine: SPF / FE428
I had a vette and was told to open the doors prior to jacking up the car, I do still with my SPF
Old 05-31-2010, 07:23 AM
FUNFER2's Avatar
If it can't handle the stress, I would not want that car.
Yes,.... close the doors on a glass body.
Regards,
Kevin
Old 05-31-2010, 07:49 AM
I have opened and closed the doors while it's on a jack. The SPF frame is strong enough it does not make a difference.
And please remember that is just a comment regarding the SPF. I'm not commenting one way or the other in regard to other manufacturers.
John Hall
Old 06-01-2010, 07:13 AM
mdross1's Avatar
I cannot imagine a Cobra frame flexing like that and it still being a good road car.My CMC car certainly has a heavy frame.
Old 06-01-2010, 10:14 AM
FUNFER2's Avatar
You're kidding me. lol
I've had my own body shop for years. Have you ever seen or heard what happens to a convertible, with a FULL frame, that's in for major repair or a restoration, and you remove the doors and others panels, little or MAJOR shifting can and will happen. That's why you ALWAYS,....weld in support cross beams.
Why with a glass cobra, would you think differently ?
I've even see drags cars with a much stronger support system in the frame, full cages and front sub connectors being used, and they also flex. Even Ferries ! (don't think so, as a dealer or owner)
With my experience in this field, you can believe me or not, that's your proactive buddy.
Will it hurt the body, probably not but, you can get stress cracks and star points. When I have mine on my 4-post lift, I open the doors, no problem but, I don't leave them open. If the body is glued/bonded down, you'll have a lesser chance. If it's bolted, you will have some deflection being glass. Lift the car on the frame, open the doors the see how the latch goes into the striker post, if it closes with no problem, don't worry about it unless you plan on having it up with the doors open, for say a few days to a week.
I have and like my Lone Star and it is among the heaviest Cobra on the market at $2,800 lbs.with two occupant's and full of fuel. It's frame is very heavy and strong and the body is the thickest I've seen. When I have it up on my 4-post lift, I often open the doors but, when done I shut them and can leave it suspended for weeks with no issues. I would NOT, leave them open for that long of a period.
I'm a body man and car builder as a profession, and have seen this happen, but it's your call my friend.
Regards,
Kevin
