Old 06-11-2010, 03:48 PM
PFSlim's Avatar
Cobra Make, Engine: Premier Motorsports
Default 390FE Oil Change
I need to get my first oil change done. I have a 390FE, Canton Oil Pan, remote oil filter, and a oil cooler. I see from previous threads on FE engines folks are talking about 9 quarts. Is there a reason I would be any different? How many quarts??
Thanks in advance
Paul
Old 06-11-2010, 06:59 PM
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
My FE Canton pan alone is 8 qts. W/remote filter and cooler, you are probably very close at 9 qts, it may vary a little due to hose lengths and dia.
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
Old 06-11-2010, 07:06 PM
Dont forget to drain the cooler and the lines or you will still have old oil in with the new oil.
