  #41 (permalink)
Old 06-21-2010, 05:26 PM
Silverback51's Avatar
Probably going to get myself in trouble here, but saying one has to much HP is like saying their manhood is to large.
One just has to learn to use what you have. After all, it's a throttle, not an off/on switch.
John Hall
  #42 (permalink)
Old 06-21-2010, 05:54 PM
BT SNAKE's Avatar
Cobra Make, Engine: Midstates Cobra, RFGT40
Talking
So you are saying a guy can't have too big of a unit....huh, like a Sonny's 802 FI.
http://image.hotrod.com/f/15350987/h...et_engine+.jpg
NOW THAT'S A HUGE UNIT!!
Not fit for Cobras ?
What ever trips your trigger.
Hersh
  #43 (permalink)
Old 06-21-2010, 06:02 PM
Original Shelby Owner
Cobra Make, Engine: 31XX Car
Default Ratios
Ernie - Aside from chassis setup, etc, if you want to keep that transmission you may want to try a tad taller rear gear, but it doesn't sound like you're too far off. I like comparing aspects to other cars that "work". Taking into consideration the entire driveline, incl tire sizes, a Cobra with 3.31 rear gear and close ratio trans is about 10.4 mph/1000 rpm in 1st gear. Your TKO-600 with 3.31 rear is 8.4. For reference, a Viper SRT10 is 9.6, and Z06 is 8.4. A 911 GT2 is 7 and Nissan GT-R is 5.3, although I trhink those may be all wheel drive, which is not directly applicable. The Viper and Z06 seem to be a good range for a rear wheel drive car. If you went to a 3.07 rear with wide ratio toploader type 1st gear of 2.78, you would have 9.3 mph/1000 rpm, which seems to be a very likeable combination with great top end too.
