Old 09-20-2010, 07:30 AM
PFSlim's Avatar
Cobra Make, Engine: Premier Motorsports
Default Pertronix Ignition
I am going to change out my standard point ignition on my cobra today. I have a 390FE with points, vacum advance, ballaist resistor, etc.
I am putting in Pertronix Ignition II and Pertronix Coil II. Has anyone did this changeover? Do I still need a ballasit resistor? Is there anything else I need to be aware of?
Thanks in advance
Paul
Old 09-20-2010, 08:14 AM
MOTORHEAD's Avatar
Paul: Did u not get an instruction sheet with the kit? It explains the wiring changes.
Ted
"When Injustice becomes Law,
Old 09-20-2010, 08:24 AM
PFSlim's Avatar
Ted
To be honest, the whole kit is coming today. Thought I would get a note out since I have read that the instructions are not that good (only heard). Therefore, just thought I would float the questions out there so I could be better prepared when it does arrive and I can go ahead and install.
Paul
Old 09-20-2010, 09:08 AM
MOTORHEAD's Avatar
Paul:
I put 2 Igniter II kits and coils on my boat a couple of years ago. Both failed 1st time out! I'am pretty sure the instructions said to remove or bypass ballast or resistance wire to get full (12-14 vdc) to the module. I had no ballast resistor , but did have resistance wire feeding the coil. Thought I had bypassed it, but had not. Low voltage (9vdc)to module = increased current draw = burned out pwr xster ! Slow trip home on one engine!
Decided it wasn't worth the risk (on a boat offshore) to rely on delicate solid state devices to drive primary motive power. Went back to points & condensor.
Shouldn't be a problem for automotive use, just make sure you read and understand the directions.
Ted
Old 09-20-2010, 09:43 AM
Paul ... for what it`s worth , I have the Pertronix on my 63 1/2 Galaxie ( 427 ) and have had no problems for over 6 years . Having said that , if you look up some posts on Pertronix , it appears that when they shifted their production out of the US , problems started and the units became less reliable . When I take the Galaxie out , I always carry the original points , condenser and mounting plate assembly just in case and changeover is fairly easy if need be ... also , there is a wiring change involved . The Galaxie has no ballast resister ... I also made sure all wiring was as direct as I could get it , power straight from the battery and I had a good solid ground to the engine block .
Old 09-20-2010, 10:22 AM
I used one on my 65 Galaxie 20 years ago and it still works fine..the kid is driveing it now
for my Cobra i used an Accel electronis dist. and have had no problems at all...
and it was an easy hook up..
Old 09-20-2010, 01:58 PM
PFSlim's Avatar
Pertronix Ignitor II and Pertronix Flamethrower II coil installed. So far.... so good!! Engine runs great again.
Many thanks to all who responded. Hopefully, I can pass along good advice someday.
Paul
Old 09-20-2010, 10:08 PM
zrayr's Avatar
Cobra Make, Engine: Fords
keep your points in the car so you can change back when the Pertronix fails.
Z.
'65 K code Mustang
'66 Galaxie 500
