09-21-2010, 06:33 PM
Cobra Make, Engine: classic roadster,408cu
Thar she blows !
Well I was taking my brother for a ride in the Black Pearl today when after a spirited run through the gears the engine let loose mostly steam from the driver side pipe and some antifreeze .It was a bummer for sure but it was amazing how many people stopped to help ! a sincere thanks to all that stopped , I did not get your names but it was much appreaciated.
I am going to tear it apart friday so watch out we shall return ...WD
09-21-2010, 07:18 PM
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
OW! Sounds like a blown head gasket or a dropped valve.
Steve
Texas Cobra Club-Seguin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
09-21-2010, 07:23 PM
Could just be a blown head gasket. Same thing happened to Greg (one of the South Bay guys). Good luck with the repair.
Doug
09-21-2010, 08:18 PM
Ca.
I was talking with Wetdog earlier and he said when it went he heard a bang (like hitting your fist on the body) and when he tried to crank it after he stopped it was locked up. He also has water in his oil. Sounds like a cylinder is full of water/ antifreeze. Hope he did not hydraulic a cylinder and bend/ break a rod.
Terry
09-21-2010, 08:22 PM
Cobra Make, Engine: Kirkham, 427 side oiler
Might be an failed intake manifold gasket, especially if its an FE. For an FE, look for water in Cyl's 1, 4, 5 0r 8
09-21-2010, 09:07 PM
Thanks again for all the tips , autopsy tomarrow I will know more then .
For as bad as it was it could always be worse ! it was priceless though watching my brother trying to get out as fast as possible because he thought it was going to blow ...WD
09-21-2010, 10:00 PM
Hydraulic lock, remove the spark plug. Do not attempt to crank engine until the liquid is vacated from the cylinder. Easy way to damage a Connecting Rod.
