| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
12-21-2010, 02:09 PM
WV
Cobra Make, Engine: SPF 2592, Shelby alum. 527
FE/Lakewood/TKO600 throwout bearing?
I have an FE, Lakewood 15210, and TKO600 (1-1/8" 26 spline), with a D0TZ-7515A clutch fork.
Which replacement throwout bearing is the correct one?
I tried a Federal Mogul FB-1625-C. It works, but it seems like the distance between the forks is slightly wider than the machined flats on the throwout bearing holder and allows the holder to rotate slightly. It might be OK, but I would rather find one that fits more closely.
Anyone know the correct bearing?
Thanks,
Rodger
12-21-2010, 03:44 PM
CT
We use Federal Mogul/BCA 614038.
12-21-2010, 05:03 PM
KY
You can also use a McLeod #16031.
12-21-2010, 07:40 PM
Ma
Throw out bearing
Hi Roger,
Without measuring the forks I can't tell if you have a 1 3/8" pressure plate. Do you have a 3 finger long or diaphram? If so you could use a large 1 3/8" fork and bearing. With those I make a press-in sleeve to fit a TKO or small input Top Loader.
Thanks,
Rodger
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
12-22-2010, 04:54 AM
WV
Originally Posted by mikeforte
Hi Roger,
Hi Mike,
Thanks for the reply, but you lost me. What should I measure to determine the 1-3/8" dimension? I have a Centerforce diaphragm pressure plate.
Rodger
12-22-2010, 05:10 AM
KY
Rodger,
Have you had this combination running before or is this a fresh new build?
You are using a correct clutch fork and any of those throw out bearings should work fine.
I think what Mike was wanting to know was whether or not the clutch kit was designed for a big input Toploader or not, as Centerforce makes 11.5/12" diaphragm kits for that application.
12-22-2010, 05:43 AM
WV
Hi Brent,
My TKO has the small input shaft.
It's been running....I'm replacing a noisy TO bearing. The original TO bearing appears to be the Federal Mogul/BCA 614038 suggested above. (I also found that one of the little retaining springs was broken and in the bottom of the bellhousing.)
I was told the Federal Mogul FB-1625-C was a good replacement. When I compared the two, they are somewhat different in the way the fork attaches, so I wasn't sure if it was correct, or if there was a better one to use.
Thanks for letting me know that any of the bearings discussed will work.
Rodger
