Old 03-16-2011, 02:06 PM
Cobra Make, Engine: ERA #539/427 Holman Moody #7HM20 from 1967
Default Jaguar Rear Brake Pads Brand Recommendation
Does anyone have a good recommendation for Jaguar rear pads. I am on the street and do not need serious metalic pads. Something rotor friendly yet an upgrade from stock. I am not racing, but need to at times slow from 90-100 quickly. Just a good all round upgraded pad.
Also, I understand the ATE Blue is a really good long lasting brake fluid.
Any advice ?
Old 03-16-2011, 06:27 PM
Cobra Make, Engine: Contemporary CCX33344 with original bore 427 SO.
This is what ERA uses....
Lucas
GDB 557
WVA 20 007 15.50
Lucas is owned by TRW
They are not supposed to squeak . I have some but have not installed them.
Check this thread
Girling Pads
Search is your friend
ATE Blue (or gold) is good...no problems at the track for me. Two colors is great when you flush you system.
Old 03-16-2011, 11:48 PM
Thanks "06" for the info. I call Bob alot. Thought I would give him a break.
Here is some info on the pad:
This is a OE Lucas/Girling Rear Brake Pad Set for a Jaguar 69-87 OE# JLM9728. These are the best pads that you can buy for your car. Each pad has an anti-squeal shim glued to the back of the pad for silent braking. As for composition each pad is made from Ceramic material for an almost dustless braking and helps with high temperature brake fade. No more black rims to clean on your car and you’ll have confidence in braking. LUCAS / TRW Lucas Brake Pads are manufactured by TRW Automotive and have always been the benchmark for the European Aftermarket, as well as being the leading suppler of disc brake systems to vehicle manufacturers including Mercedes, Audi, Volvo, Suzuki, General Motors, Ford, Nissan, Toyota and Mitsubishi. Excellent Brake Performance TRW's stringent performance specifications ensure that all Lucas pads have excellent fade resistance in most braking conditions, as well as good pedal feel and excellent recovery. Lucas brake pads work when cold and continue to perform at very high temperatures (with a stable friction co-efficient from 100 °C to 650°C). Reduced bedding-in time All Lucas brake pads are scorched at 650°C eliminating initial fading and reducing the bedding-in time. The scorching process superficially heats the surface of the friction material to release residual gases and resins remaining after the manufacturing process. Low Noise All Lucas pads are fitted with hot-glued rubber composite shims. This reduces vibration - the major cause of brake noise. When Lucas brake pads are fitted to your vehicle they will provide you with absolute braking confidence. Lucas Brake Pads provides Performance when it counts.
R/
