Old 02-09-2011, 09:40 AM
Cobra Make, Engine: B&B,351w
Default Timing light leads when battery is in trunk?
Hey guys,
I'm borrowing a friends timing light and was wondering if it's okay to hook up the positive lead to the back of my alternative? I have a self exciting (1 wire) alternator, the battery is in the trunk.
I don't want to fry this guys timig gun so any help is appreciated.
Old 02-09-2011, 09:46 AM
xlr8or's Avatar
Do you have a starter selenoid on your firewall? Use the batter side of that if you do.
Old 02-09-2011, 10:05 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by mbeers6 View Post
Hey guys,
i had the same problem, after making some scary arcs from putting my light leads in precarious locations i installed one of these on my firewall, makes life alot easier.
can be had from most auto stores like NAPA,.......
Fred B
Old 02-09-2011, 10:10 AM
Yes, but it's on the wrong side of the firewall It is underneath the dash.
I guess I could just pull the battery from my toyota and put it on the ground to be safe.
Thanks for the info on the Bussmann, I'll look into that.
Old 02-09-2011, 10:16 AM
Rick Parker's Avatar
Attach the positive (red)to the cable on the starter solenoid, whether it is on the fire wall or at the starter itself. An alternative would be a "hot" wire at the fuse box. Keep all attaching cables free of the headers. You friend will thank you for it.
Old 02-09-2011, 10:20 AM
392cobra's Avatar
6th Generation Texan
I connect the positive lead of my timing light to the positive output on the back of my alternator.
Old 02-09-2011, 10:24 AM
FWB's Avatar
FWB FWB is offline
as a side benefit, the bussman really cleaned up the underhood wiring. i used it as my positive lead to all the extra stuff. it got direct feed from the battery and has 1\4-20 studs as posts, so you can put a really heavy wire on it and its a fuse block too.
Fred B
Old 02-09-2011, 12:56 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
I ran the battery to a large aluminum plate that was engine-turned. It works great for connecting power.
Use the big fuse before the plate is you decide to put a connecting stud.
Old 02-09-2011, 03:07 PM
SuperHart's Avatar
Send a message via AIM to SuperHart
Clip the red lead from the timing light to the red terminal on the rear of the alternator. Clip the black timing light lead to any ground source and the light should work just fine. That's how I do it.
Old 02-09-2011, 03:44 PM
DanEC's Avatar
That's an interesting question. I had a Pontiac Trans Am in the 70s that I moved the battery to the trunk in - I did a lot of tuning on it but I can't remember how I powered my timing light. I must have put the lead on the starter solenoid where the battery positive lead terminated??? It's hell getting old.
Old 02-09-2011, 05:34 PM
FWB's Avatar
FWB FWB is offline
or you could get a battery operated light
Fred B
Old 02-09-2011, 05:45 PM
Use a pair of jumper cables, connect to battery in trunk and timing light.
Old 02-09-2011, 07:12 PM
I just always use an extra battery on the ground.
" It ain't no big deal"
Old 02-10-2011, 05:13 AM
Roscoe's Avatar
I also use the alternator hot lead
Roscoe
Roscoe
Old 02-10-2011, 06:28 AM
Years ago I used the 12 volt positive connection on the COIL and the other lead to ground. That works on standard ignition systems. It does NOT work with MSD ignition. Turns out the MSD can supply as much as four hundred volts to the plus side of the coil. Blew out the timing light in a heart beat....
Old 02-10-2011, 10:46 AM
DanEC's Avatar
Now that you mention the coil I think that may be what I use to do with my old Trans Am with a trunk mounted battery. Hooked it up to the coil and ground like a dwell meter. Should of remembered that.
Old 02-10-2011, 01:31 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Consider for a moment...What range of voltages come off the alternators hot lead, especially if you connect the timing light between the alternator and the voltage regulator. Be sure your timing light can handle the higher voltage...Since most newer timing light are multi-purpose tools they should be ok. But the older - single purpose timing lights my get toasted...
SPFWiringDiagrams@Comcast.net
Old 02-10-2011, 03:50 PM
JST4FUN's Avatar
Cobra Make, Engine: SOLD-SPO2660, Southern Automotive 406FE, TKO-600
Any one have personal experience with the MSD AA battery powered unit? Specs says it's good to 5000rpm. I'm in the market for a timing light, this one would eliminate concern of where to pick up power.
Thanks!
Joe
Have fun and enjoy life, because when it is over, it is too late!
Old 02-10-2011, 04:07 PM
Silverback51's Avatar
Thanks!
I have one and it works great.
I just make sure to always remove the batteries when I'm done using it.
John Hall
Old 02-10-2011, 05:06 PM
Roscoe's Avatar
I have an MSD digital ignition and use the alternator. It's on the same side as the dampner.
Roscoe
Roscoe
Tags
gun, leads, timing light
