Old 05-12-2011, 08:44 AM
Cobra Make, Engine: Custom built, 427 side oiler with dual fours
Default erratic tach Stewart Warner
My cobra has been on the road since1992. I had to replace the tach about 5yrs ago because it would be erratic, jumpy, and would often indicate twice the actual RPM's.
Now I'm having the same problem. I wonder if the MSD ^AL is causing a problem with the tach circuitry oor if I just got two bad tach's.The is a company , APT that supposedly repairs them and makes them more "friendly" with MSD units.
Any information would be appreciated.
Steve
Old 05-12-2011, 11:26 AM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
First, check that it is properly grounded. The "-" should be connected to a good, solid ground, as well as the case.
I had one SW tach fail, and replaced it. I recently had a problem with the tach (again) but it seemed to be related to having managed to drain my battery---once I recharged the battery with my garage charger the tach worked fine.
DD
Dangerous Doug
"You're kidding, right?"
Old 05-12-2011, 01:14 PM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
My SW tach only works when it wants to, otherwise, it reads more than actual...
I have the MSD 6AL and I have the MSD tach adapter box. 14 years ago I had the SW tach worked on by SW and also had the 6AL worked on by MSD and changed the tach adapter a couple of times. Nothing really made a difference and so I gave up eventually.
Maybe the tachs or the MSD stuff play better together today, 14 yrs later, but I just listern for when to shift. With the quick revs from my 540, I can't look at the tach anyway
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
Old 05-13-2011, 01:51 PM
I've only had two S&W tachs, and they both had crazy-wavy needles. I had the S&W in my LAX "repaired" by an auto intrsument repair shop, and it worked fine, for the first 50 or so hours. Then it started acting erratic, although sometimes it works just fine. The repairman mentioned something about the front bezel being rolled over the back shell of the tach, chipping chrome, and maybe not going back together correctly.
Old 05-15-2011, 03:44 AM
Cobra Make, Engine: CR 347 ford
Default tach
does anyone have diagnostic information on S_W tachs,voltages etc.
Or where i can get it. This is my second tach to just quit. I am using the tach signal connection on a GM type HEI
thanks
Wally
