Old 05-14-2011, 06:49 PM
Default msd question
hi,
yesterday i put a MSD pro billet distributor in my car, 5.o ltr efi, car was running fine with standard dist but now breaks up at about 4 k rpm, idles fine and double checked timing. also put new coil and spark plug wires. any thoughts on what could cause this?
thanks in advance for any replies.
Old 05-14-2011, 06:59 PM
lovehamr's Avatar
Stolen Avitar
Check the center electrode contact inside the dizzy cap. Should be carbon but nice and smooth as well as spring loaded. Also take a look at the rotor contact point for the center electrode and for signs of arcing in the cap.
Just a known place to start. Steve
Old 05-14-2011, 08:21 PM
Cobra Make, Engine: Unique 289 FIA, 347 stroker
Check out the rev limiter.
Old 05-14-2011, 09:38 PM
Silverback51's Avatar
MSD is very sensitive to voltage input.
The first time I had an issue I replaced everything in the system. Found out it was the voltage regulator. Put in a new one and all was fine.
John Hall
Old 05-14-2011, 11:56 PM
Gaz64's Avatar
5.0 EFI? Could be a distributor signal mismatch with the ECM.
Old 05-15-2011, 09:07 AM
Mac VABCH's Avatar
Cobra Make, Engine: BDR #250
Check the TFI module on the front of the distributor and the connections at the coil.... The TFI needs to have dialectric compound on the back...
Old 05-15-2011, 03:35 PM
DAVID GAGNARD's Avatar
That's what I was thinking..........maybe check on the FFR forum and see what you can come up with.........
DAVID GAGNARD
Old 05-15-2011, 03:48 PM
thanks for the replys guys, shall check all out.
