07-26-2011, 04:42 AM
NJ
Cobra Make, Engine: B & B
Neutral
Clay Bar treatment
I tried one of those clay bar treatments yesterday and I have to say it works great and it was also easy to do!
07-26-2011, 04:56 AM
Cobra Make, Engine: LoneStar 427 SC, "Red Venom", 351W B/S 400 HP, TKO 600 .64 OD
Yep, I do it once a year on my daily driver and the paint looks fantastic. Follow it up with some Zaino and it will be amazing.
Randy
07-26-2011, 05:57 AM
Me
No better way to smooth the paint before carnuba.
07-26-2011, 06:46 AM
Ne.
The product works great. I'm a auto body/painter, so be careful.
1- choose a known company as there's cheap knock-offs.
2- make sure you wash the car first, to get most debris off the paint.
3- use good microfiber towel's.
Kevin
07-26-2011, 12:24 PM
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Clay bar with water/ little Dawn blue dishwashing soap.
Then Zaino.
You will never go back, ever.
Wayne Rogers in Hideaway, Texas
07-26-2011, 12:32 PM
MT
I have excellent results using Griot's Speed Shine with their clay bar. Be sure to stop swiping the clay across the surface as soon as you feel the slightest drag. Re-lubricate the surface and continue. Repeated swipes over an area rarely make the surface smoother-one is usually enough. Work small areas at a time and always wipe the surface free of lubricant before moving on.
A beautiful car, precisely assembled. Unfortunately I don't fit. Sold it after four hundred miles. Well, at least now I know a Cobra is not a car I can own.
07-26-2011, 01:13 PM
Ne.
I agree, that you can also use a spray detail wax for lubrication, instead of water.
Kevin
07-26-2011, 01:22 PM
Cobra Make, Engine: SPF #1019
I'm another Zaino fan. I use a squirt bottle with a cap full of car wash soap, then fill to the top with water. This solution works well to keep the paint surface lubricated while using a clay bar. And it is a cheap solution to make...
07-26-2011, 01:34 PM
Ne.
I don't care for the use of car wash soap, as it can dry unless you're working fast and keep the surface wet. The spray instant wax is not an issue, fast & safe. Especially if you have hard water, as it will put on some of the chemicals you're trying to get off with the clay bar.
Kevin
