Old 08-03-2011, 04:51 PM
lal Naja's Avatar
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Default Breakers versus fuses
Anyone use breakers in place of fuses? Pros & Cons would be appreciated.
What about auto-resetting type that will close when the overload condition is corrected?
Look forward to the comments.
Arthur
Old 08-04-2011, 04:24 AM
Cobra Make, Engine: LoneStar 427 SC, "Red Venom", 351W B/S 400 HP, TKO 600 .64 OD
This is kind of funny because the aviation guys are moving away from breakers to fuses. Breakers cost more, take up panel space, and are slower than fuses. Other than that, there's no reason you can't use them.
Randy
Old 08-04-2011, 04:52 AM
Tommy's Avatar
My car is atypical in that it was built as a dedicated race car. The original builder installed switch type circuit breakers from a WW II aircraft (a B-29 I was told). So, for example, the toggle switch for the electric fuel pump has the circuit breaker for that system built in. If the circuit breaks, the toggle on the switch drops down to the mid position. It is reset by moving the toggle to off and then back to on. If the breaker is too hot to reset, the driver can override the break by holding the switch in the on position. I assume this was done to allow the driver to complete the final lap of a race at the expense of his equipment and safety.
This choice does limit the look of your switches, but it makes the wiring simplicity itself. There are no hidden fuses or circuit breakers. I've driven my car like this for almost ten years with no problems.
Tommy
Previously owned EM Cobra
Old 08-04-2011, 06:18 AM
CobraDan's Avatar
Circuit Breakers
At Del City they have many types of automotive circuit breakers and at half what others charge but for small oders the shipping might be 4 times your purchase price of the needed breaker.
Dan Wulff
