Old 08-23-2011, 04:55 PM
Default What Are All the Parts In a Cobra?
So most people when buying a kit know what they need or the manufacturer automatically supplies it. If you were building a cobra from scratch and had the body, frame, wheels, engine, engine components, transmission, side pipes then what else would you need? Here is the start of my list:
Brakes
Shocks
Rims
Tires
Windshield
Front and Back Lights
Turn signals
Emergency brake mechanism
Gas tank
Battery
Wiring harness
Seats
Carpet
Gauges
Pedal assembly
Hinges and latches
Wiper Assembly
Jacks or bumpers
Roll Bar
Gas cap
Dash
Weather Stripping
Mirrors
Horn
Seat belts
Sway bar
Old 08-23-2011, 05:05 PM
Average Guy
I had to get a 9" rear axle and shorten it and make a drive shift to fit.
Old 08-23-2011, 05:14 PM
SuperHart's Avatar
Send a message via AIM to SuperHart
The Ford 9" rear from a 1978 Lincoln Versailles is pretty close to what we need measured flange to flange AND it comes with factory 11" disk brakes with built-in cable operated emergency brake and 5-lug hubs. I discarded the 2.78 28 spline open pumpkin and bolted in a 28 spline posi with 3.50 gearing. All I had to do was fabricate and weld on mounting pads for the shocks and four-link control arms.
Old 08-23-2011, 05:30 PM
well its in pounds sterling, and doesnt have all the above detail, but might still be of interest.....
Build Cost : Crendon Replicas
Crendon 427, in the making
http://crendonreplicas.com/
Old 08-23-2011, 06:49 PM
randlej's Avatar
Cobra Make, Engine: Lonestar Classics
This will get you started. However, know that this is the basics. I added a lot to this.... lost count in fact. Really depends on your build level.
LS427 Roadster Competition Kit Pricing
2009 Lonestar Classics - 351 W
Old 08-23-2011, 09:33 PM
Ralphy's Avatar
You mention frame, however does it include the front suspension?
Old 08-23-2011, 09:55 PM
Cobra Make, Engine: ERA FIA 2008/351W/TOP-LOADER
There needs to be more information given for help here. When I look at this list I just see the basics. The wiring for example should include: wiring harness, quality connectors, extra wire, electrical tape, mounting materials, zip ties, shrink wrap, switches, ignition, specialty connectors, ground straps, etc. Each one of those items listed rolls over into 5 to 10 fold of "other" items needed for the installation. My gas tank for example: gas tank, stainless steel mounting straps, rubber insulation, custom machined fill neck, sending unit, supply lines, vent hose, roll over valve, gas cap. All of those incidentals adds up real quick!! Trust me! The make of the kit and some other descriptions would help here. Regards, Matt
Old 08-24-2011, 05:49 AM
mdross1's Avatar
When scratch building anything it always boils down to focusing on the problem at hand.Not let the total project overwhelm you.Finish one thing at a time get it behind you the end result is so much more enjoyable.Also leaves you with pretty good confidence that all is right.The first few shake down runs will help build that much needed confidence.
Old 08-24-2011, 07:04 AM
G-Pete's Avatar
Talent, Time and Money...
DRB GT40 MK1 red #49- sold
SPF 2063
Old 08-24-2011, 05:22 PM
Dimis's Avatar
Now that's funny!
But, funnier still, I lack all three...
Old 08-26-2011, 12:57 PM
dallas_'s Avatar
You're scaring me Aedds.
What are you up to??
Old 08-26-2011, 01:08 PM
LOL!! You never know....
Old 08-26-2011, 01:38 PM
LMH's Avatar
LMH LMH is offline
The big one I don't see addressed is suspension.
Alba gu brąth
Old 08-26-2011, 02:52 PM
392cobra's Avatar
6th Generation Texan
This is a real good list from Mickmate....
mickmate
Original Cobra Parts
I copied this list from my previous thread as I wanted it over in this forum. Comments or additions appreciated. There are some contradictions in the list I think mostly due to availability while manufacturing and added/aftermarket stuff that was done to some early cars and construed as original.
Ashtray-Austin Healey 3000
Boot (trunk) handle 1961 Austin Mini MkI
Bumper overriders-Jag XK140
clock 289: Ford Galaxie
Clock- 1962 Fairlane (Galaxie has different trim ring)
diff: Aston Martin, Iso Griffo
Directionals- Mini, Minor
Directional switch-early- 66 Beetle (floor button dip switch)
Directional switch-late- Spitfire TR6? dip switch incorporated
Expansion tank- Galaxie (turned round for left hand outlet)
Front spindles,uprights-AC part
fuse block early 289, Daytona coupe, and 289 FIA: Jag xk120
Gas cap comp: Double decker bus
Street Gas/Petrol cap- 1964 Ceandess 348 Sunbeam and Norton motorbike
Headlights-59-68 Austin Healey 3000
Master cylinders/reservoirs-61 Triumph TR3 0795(Girling stuff)
Motor mounts- 64 Galaxie etc 4850 "L" moulded 2 bolt early
Motor tranny-Galaxie, Fairlane etc
Number Plate light 1958-69 Austin 768 or TR3 18913
Oil cooler- Mocal
oil overflow tank 427: modified lawn mower tank
oil overflow tank 289 FIA: Marvel Mystery Oil cans
Park brake-SI E type
radiator early 289 : Corvette
radiator (289) fan motor: Lucas
rad fan (427 sc)motors: Mustang heater blower motors
rad fans (427 sc): industrial electric motor fan (6 blades)
Rear view mirror dash-Austin Healey Lucas 104
Rear view mirror fender-Talbot Berlin Junior 300 Mercedes Porsche
seat tracks: Aston Martin DB2, DB2/4, Mark III, DB4, DB5, and DB6 (Leveroll on knob)
shifter ring and boot: Falcon
shifter handle 427: modified Mustang
Shifter trim ring and boot-Galaxie stamped at 6'oclock with FoMoCo
Speedometer cable 427 : Mustang
Steering rack-Originally Cam Gears Ltd 18993 MGB (shortened input shaft)
Steering wheel- Mota Lita 16" 1958 Sunbeam and others Derrington
Steering shaft-BMC Rover 62-67 MG originally spliced together with tube
Street car air splitter trim-1965 Beetle (again) running board trim
Taillights (rectangular)-1952 Hillman Minx (British Chrysler)
Taillights round- Austin Healey 691R
transmission 289: Lightweight Galaxie
transmission 427: Mustang HEH BY (modified with small input big out)
Tonneau/top snaps-MG Austin?
Twin fan motors- 1962 Falcon heater fan motor
Twin fans- 5 blade aluminum 8 1/2" diameter
wheels early 289 comp (LeMans) cars: D type Jaguar
Windwings, visors-Austin Healey
Wipers bezels etc-1955-73 BMC/Leyland/MOWOG etc 1134K
mickmate
Old 08-26-2011, 07:37 PM
LMH's Avatar
LMH LMH is offline
That's quite a list! I hadn't seen that before.
One thing about the wheels Nick, the early Le Mans Cobras (2131 and 2142) used the 10-slot, one piece, Dunlop wheel from the Jaguar E-type Lightweight. D-Types used a two piece Dunlop with round holes.
I know, picking nits!
Alba gu brąth
