Old 08-24-2011, 07:52 AM
Default Ear popping?
OK, so I have a silly question...
EVERY time I drive by BDR over about 20mph and below 60mph my ears clog up like I'm taking off on an airplane. It's like the shape of the windshield and plexiglass side flairs create a vacuum in the cockpit at those speeds.
My ears have always been sensitive to pressure changes. But I was NOT expecting this while driving the Cobra. I have driven tons of other convertibles and roadsters and never experienced this before.
I was curious if anyone else has experienced this, and if there is a "fix"
It's certainly not a major issue, but it is a bit annoying....
Old 08-24-2011, 07:55 AM
Jerry Clayton's Avatar
try a set of ear plugs
Old 08-24-2011, 07:59 AM
I would prefer not to wear earplugs.... I thought of that.
Is this common?
Old 08-24-2011, 08:35 AM
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Drive with your mouth open to equalize pressures. LOL
The Nut
Enough is enough. Too much is just right ( C.S )
Old 08-24-2011, 08:56 AM
xlr8or's Avatar
Get a cloth seat cover so you won't be pulling a vacuum everytime you step on the gas.
Old 08-24-2011, 09:03 AM
Ralphy's Avatar
Old 08-24-2011, 10:53 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Earplugs are a good idea anyways.
But I'm leaning more towards Ralphy's idea.
Funny how you never experienced this with other open cars...
The turbulence in a Cobra's cockpit should create a vacuum.
Were the open cars you've been in modern? They design them so good now.
rodneym
Old 08-24-2011, 11:17 AM
Modern and old.
I have a 1965 3000 mark III Austin Healey that it doesn't happen in... And I used to drive a Mustang Convertible (1989) all the time without ear popping...
Weird...
Old 08-24-2011, 11:19 AM
392cobra's Avatar
6th Generation Texan
Chew tobacco or maybe gum.
Old 08-24-2011, 02:54 PM
Tried gum. I'll pass on the tobacco.
I guess I'll try earplugs and see if it helps. I have a set of in ear headphones. I'll try that first...
I guess I'm the only one this happens to...
Old 08-24-2011, 03:40 PM
randlej's Avatar
Cobra Make, Engine: Lonestar Classics
Do you have wind wings and visors? Might help if not.
2009 Lonestar Classics - 351 W
Old 08-24-2011, 04:01 PM
Have both. I'll try without them. I just like the way they look...
But I'll try. Thanks
Old 08-24-2011, 04:32 PM
Happens to me all of the time. Even in my DD (four door sedan). The wind buffering around your ears I guess. Of course I have hearing problems anyway.
Terry
Old 08-25-2011, 12:19 AM
tkb289's Avatar
Experiment with the wind wings and visors set to various angles ... maybe even try setting them in an asymmetrical configuration, so as to disrupt the airflow ... could be worth a try.
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
Old 08-25-2011, 12:21 AM
Try adjusting the wings and visors to change the wind dynamics at speed... you may find a comination that helps.
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 08-25-2011, 06:26 AM
Modena's Avatar
I'm struggling to see the problem here, just don't go under 60mph
Ben in AU
Old 08-26-2011, 02:03 PM
bobcowan's Avatar
Caused by eustacion tube dysfunction - a pretty common problem around here. Ask your doctor for a prescription for Nasonex nose spray, and use it every day. That usually resolves it.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
