Old 08-26-2011, 10:49 AM
Cobra Make, Engine: Superformace, Big Block
Default Selling My Show Quality Big Block Cobra
Before I put my Cobra up on Cobra Country I wanted to let everyone here know its available.
This Superformance 427S/C, SPF390 is registered as a 1965 and is located in Arizona. Factory Guardsman Blue/bright white racing stripes; buffed and waxed to a mirror finish. Under the hood: custom built, no expense spared (By award winning RHP) stroker 501 cid big-block Ford which belts out dyno-proven 550 hp/ 600 ft./ibs. of torque. Broken in on Joe Gibbs racing oil. 10.3:1 compression ratio, Scat crank, H-beam rods, ported & flowbenched aluminum Cobra Jet SVO heads, forged aluminum pistons, custom-ground cam, custom-built 910 cfm carb, Bosch HD starter, Blue Thunder intake and air cleaner. Geartrain: McLeod Kevlar clutch & pressure plate, Tremec 3550; Ford IRS 8.8” with 3.73:1 final-drive ratio. Suspension: Avo adjustable coil-overs with custom H&R front springs and new poly bushings. Rolling stock: factory Trigo 15” pin-drive wheels with Yokohama Avid upgraded tires. In the cockpit: factory Smiths gauges, hardwood-rimmed Mota-Lita steering wheel, premium German leather and black wool carpet, Deist 4-point racing belts, dropped floorboard for additional legroom, original tonneau cover.! It’s continuously stored in a garage with a car cover on it when it’s not being driven. Annual nut & bolt inspections and oil changes using VR1 20-50 racing oil. It’s a very reliable and well mannered.
$45,900.00. PM me if you would like more information
Old 08-26-2011, 11:51 AM
You might want to mention how many miles are on it, how long you've had it, what the custom cam specs are.... (Not to be a wise ass, that's just some of the things I would look for if I were in the market.)
Old 08-26-2011, 12:15 PM
Car has 18000 miles but only 2000 on the motor. As far as the cam is concerned I will get the information once I get home.
Thanks for the input.
Old 08-26-2011, 08:27 PM
Cam:
Old 08-26-2011, 08:28 PM
Let me know if anyone needs more info.
Old 08-26-2011, 11:04 PM
Cobra Make, Engine: Black CSX 4910, Roush 511 8 stack
Beautiful car, To sell it I wouldn't waste time waiting getting it on Cobra Country. My Superformance was posted on this forum for 4 weeks with no repsonse and sold in less than 2 weeks after going on Cobra Country. Good luck!
Old 08-28-2011, 09:47 AM
Car is now on cobra country.
