Old 08-30-2011, 01:28 PM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
Default Stub axles for '76 Jaguar rear
Can anyone recommend a company that can make a stub axle for the Jag rear???
TIA
Old 08-30-2011, 02:30 PM
Jaguar Accessories
Great guys to deal with
Old 08-30-2011, 03:58 PM
If you're the same person I talked to this morning, I think you mean half-shaft, not stub axle.
Old 08-30-2011, 04:18 PM
If you need half shafts and not stubs, I have an extra set I'd sell. john.chamorro1@gmail.com
Old 08-30-2011, 04:35 PM
mickmate's Avatar
He's looking for 31 spline stub axles. He broke the Jag 16 spline ones, don't know how.......
mickmate
http://www.actoncustom.com/
Old 08-30-2011, 04:58 PM
Nice pix ! I don't have the stubs.
Old 08-30-2011, 06:26 PM
Mdman352's Avatar
Mick,
This is the launch where I disintegrated the universals and the half shafts.
I broke the stub axles in February when Tommy Goldstein of Ferrari vs Cobra fame rented the track in Maryland to practice and had the local Cobras come along to play.
And the cause of all this self inflicted misery...
Old 08-30-2011, 06:39 PM
Mdman352's Avatar
Old 08-30-2011, 07:32 PM
mickmate's Avatar
David, one of the places I was thinking of Ring & Pinion Gears | Axles Parts | Drivetrain Parts
and what about these guys Summers Brothers - Manufacturer Of High Performance Axles For All Of Your Racing Needs!
mickmate
Old 08-30-2011, 08:29 PM
67JET's Avatar
Cobra Make, Engine: Holliday Motorsport/396 GM / 4 speed / Jag rearend
Looks like a good launch. Any body or frame damage? I have wondered what happens when you brake a half shaft. Does the tire fold in at the top and the broken shaft beat the crap out of everything until you come to a stop (which would happen really quick I would think). Is that where having the upper part of the hub connected to the frame by a watts linkage also a benefit and would help prevent damage or would it destroy that too? The forces would be different (side to side) than what the watts was intended to control (front to back), but would it help in that situation? Good luck with a quick and not to pricey fix.
Old 08-31-2011, 05:40 AM
31-splined axles are available from Mark Williams. 303-665-6901.
Old 08-31-2011, 10:26 AM
Mdman352's Avatar
No body or suspension damage thankfully. I got the car to roll back to the trailer
A Jag rear was made for a 230 HP 6 cylinder with 700 series bias ply TREADED tires. When you put 500 HP and MT drag radials in their place the result eventually will not be pretty, nor cheap. I have some drag radials for sale real cheap....
Old 08-31-2011, 01:03 PM
Originally Posted by Mdman352 View Post
A Jag rear was made for a 230 HP 6 cylinder with 700 series bias ply TREADED tires. When you put 500 HP and MT drag radials in their place the result eventually will not be pretty, ...
Jaguar ended up using it in their 12 cylinder cars too. Much heavier cars, with up to 4.11 differential gears with the overdrive transmissions.
Shelby chose to use the differential (with very minor casting changes) in the 427. True, it wasn't meant for drag racing, but it has held up pretty well otherwise.
Old 05-27-2012, 07:53 AM
joyridin''s Avatar
I know this is an old post, but did you end up having a set of 31 spline axles made? If so, how did they come out and how much did you pay?
Old 05-27-2012, 09:48 AM
Hotfingrs's Avatar
Whatever he used, it wasn't enough, because he broke again a couple of weeks ago....
Jack
XSSIVE .....
Old 05-27-2012, 10:09 AM
Mdman352's Avatar
Jack is correct. Twisted the half shaft like a pretzel. This was from a "off idle" launch. Those Avons HOOK!!!
Old 05-27-2012, 10:38 AM
At least the stub axles held up this time!
Where did you get your stub axles in the end and where did you get the 31 spline differential or spider gears? I have a couple Kirkham 19 spline differentials I would like to switch over to 31 spline if possible.
Old 05-27-2012, 07:03 PM
mickmate's Avatar
Hey Bob that shouldn't be hard to go from 19 to 19. Don't they use a 31 spline Auburn gear?
mickmate
Old 05-27-2012, 07:54 PM
Thanks Nick, I corrected it in my post. I haven't had a chance to rebuild the Kirkham diffs yet, so exploring the costs/trouble in changing over now to the 31 spline stubs/ spider gears. (even though I already bought the stub axles for the 19 spline unit).
I didn't know that Auburn made a 31 spline Dana 44 differential? I'll have to check that out. Who makes/sells the 31 spline stubs these days?
Old 05-28-2012, 05:33 AM
Mdman352's Avatar
Moser axles, Eaton Tru-Track posi. Doubled the wall thickness on the half shafts this time. whats next?????
