Old 10-29-2011, 06:04 PM
Default Rear end oil cooler
I'm looking for good set-up pics and pump information on rear end cooler plumbing . Dana 44/CSX/Jag not 8.8 or 9" Ford.
Old 10-29-2011, 06:32 PM
Go to www.wuthitdesigns.com/cobrastory.htm. Scroll down the page and there are a few of the pictures on how the differential cooler was plumbed. My csx is plumbed the same way.
Old 10-29-2011, 06:34 PM
I made a typo as it is cobrastory
Old 10-29-2011, 06:38 PM
it is cobrastory
Old 10-29-2011, 08:31 PM
I have seen that site . It is great to bare bones old school resto.
I was hoping to see more options .FIA type . (ERA FIA)
Thanks for the help
Old 10-29-2011, 08:42 PM
mickmate's Avatar
I have a couple of closer shots of the cooler but you can see it pretty well on 3015. You also see the twin Facet fuel pumps they used. They don't like pumping cold diff oil as they are only fuel pumps so you had to warm the diff oil up to get them to pump. The problem was they were manually switched and often forgotten in the heat of the moment racing them and they still cooked rear ends as they don't work when they're not switched on.
mickmate
http://www.actoncustom.com/
Old 10-30-2011, 03:37 AM
Default Room under the car for a Diff cooler setup
4SECA Before you go out and buy things, you might want to touch base with Bob at ERA. With the different frame we have there is not alot of open room under the car. I have seen the setup on the orginial cobras like Dick Smiths and have pictures. The room is tight. The other tought is buying a 3 or 4" bildge fan and use the right side foot duct to tap into and run air down the tunnel to help cool the trans and the rearend brakes. If you are going racing, outboard brakes are the better way to go. I run 3 fans under the hood of my car. 2 for getting hot air out of the fender ducts and cool the motor and 1 for cool air down the tunnel. I have fire insolation on the tunnel and it gets hot in the summer. The brakes get soft with the pedal and the trans will not shift smooth after a 15-20 minute run on the track. Moving the dead air out has helped. Weldon sells a differential pump. You will need to drill and tap the jag housing top and bottom, add a cooler that will get some fresh air to it. Wiring with a fuse and relay and switch to run the curcuit. The small fan is cheaper to do and works.
Got to ask, Are you track racing? if not, and just street driving with a visit to the track, you reallly don't need a cooler. Top of the line Diff oil will work fine. Rick L.
Old 10-30-2011, 07:43 AM
Thanks Rick
I have many hours building Cobras (CSX,ERA.Comtemporary,Bulter).Looking for ERA FIA or 427 rear end cooler pics .
Track car? I say build the car so you can't break it then try to break it.
Old 10-30-2011, 08:48 AM
Originally Posted by 4SECA View Post
Thanks Rick
I expect no one will want to waste anymore time with you, those that do are probably bored
Old 10-30-2011, 08:59 AM
Cobra Make, Engine: 2004 Kirkham 427 S/C, Shelby 496C.I.
What about using the pump circuit and power the circuit with ign. switch on, but put in a temperature switch in the bottom of the diff. housing to only turn the pump (s) on when temperature is reached? I've seen Stewart Warner temp switches made for that purpose.
