Old 10-30-2011, 06:27 PM
Newsnake's Avatar
Cobra Make, Engine: Unique 289 FIA, 302
Default Turn signal won't turn off
Hey,
My right turn signal keeps on flashing no matter which way the signal lever is placed. Even when I turn left ( both of them flash). Any advice would be appreciated.
Old 10-30-2011, 07:24 PM
JLip's Avatar
Default Turn Signal
Silly question but did you pull the turn signal relay that is located under the dash? I had a similar problem and replaced it with a new one bought at Auto Zone and all works fine. Good luck and hope this works!
Old 10-31-2011, 05:11 AM
Most likely the switch itself, if the front signals are lighting.
Old 10-31-2011, 10:24 AM
Rick Parker's Avatar
Car may be totaled.
Old 10-31-2011, 10:55 AM
Cobra Make, Engine: Superformance #678
Yeah what Rick said lol, but seriously, pull the flasher unit and swap it with the other one. If it goes to the other turn signal you need a new flasher relay. If it stays the same the contact in the turn lever is stuck.
Old 10-31-2011, 06:59 PM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
did you turn on the hazard flashers on accident?
