Old 02-28-2012, 10:46 AM
Clois Harlan's Avatar
Default Welder Back Burn...Welders help
I was welding up some brackets and with my little Lincoln Weld Pack 100. I use gas 75% Argon and 25% CO2. I was using L56 .030 Mig welding wire (no flux) when my welding wire started burning back at the spool wheels and in fact welded the wire to the wheels. Replaced the inner liner but that was not the problem. Still back burning to the welding spool.
Anyone have any ideas what could cause this and if it is worth repairing? Welder is about 6 years old.
Clois Harlan
"Let's roll"
"Be part of Something Good
Old 02-28-2012, 10:59 AM
Clois, that would suggest a short between the spool and the mount. Wherever there is that much heat there is current flowing (or trying to). You should have no current there. Call Lincoln, they are usually very helpful.
Old 02-28-2012, 12:25 PM
G-Pete's Avatar
...check your polarity.
DRB GT40 MK1 red #49- sold
SPF 2063
Old 02-28-2012, 01:50 PM
Good point. If he switched from flux core to non-flux (w/gas) that would create some unintended consequences.
Old 02-28-2012, 05:07 PM
Possibly bad ground or ground clamp on the work.
