Old 05-21-2012, 06:37 PM
Cobra Make, Engine: Everett Morrison
Default Brake Questions what is this ?
I am going to put a few questions up right now but first
I need to know" What the hell is this ?
It's in my trunk It's part of the brakes and I hate it
it's big and ugly
Car is EM buillt in 92 chassis #25
I just finished ripping 90% of the suspension out "
Brakes were nothing to brag abpout. Sloppy at best
Old 05-21-2012, 07:03 PM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Vacuum pump?
Old 05-21-2012, 07:10 PM
Tommy's Avatar
This is truly a wild guess. On your other thread, you note that you have no parking brake action. Is it possible that this device captures and maintains pressure in the brake lines to act as a parking brake? Is it wired electrically to something in the cockpit the driver could use to set the brake?
Tommy
Previously owned EM Cobra
Old 05-23-2012, 07:03 PM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
By golly, it looks like a still to make moonshine while on the road.
Old 05-23-2012, 07:25 PM
Obviously it's a transmogrified thermobulator. Duh!
Old 05-24-2012, 04:15 AM
That's a dual remote brake booster, probably from Master Power Brakes (mpbrakes.com).
Old 05-24-2012, 05:39 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Oh come on guys, give the guy a break; it's obviously the "Flux Capacitor"
SPFWiringDiagrams@Comcast.net
Old 05-24-2012, 07:30 AM
DonC's Avatar
Did a little research and found out it's a remote framiscam housing.
DonC
Old 05-24-2012, 12:45 PM
Outwest34au's Avatar
That is the most hideous remote brake booster I have ever seen, in fact it looks like two units back to back. This is a principle of braking that goes way back, I remember these types of brake boosters from old Austin buses and other old pommy trucks.
Basically, when you press the brake pedal down it moves some fluid to this contraption in your boot area as a pilot signal, all the action then happens, the booster diaphraghm is (should be) connected to engine vacuum, this controls some valves and pistons etc and by black magic HIGH pressure brake fluid is pushed to your wheels. Here is a similar unit,
Here is australia the VH44 booster has been the popular equivalent for circa 600 years. Pictured below, note the actuating master cylinder on the right.
You could rip it all out and put a firewall mounted booster/ master cylinder combo in. You would obviously require some space in the engine bay, re-plumb some if not all brake hardlines and possibly change pedal setup or ratio. I use a PBR Ford Falcon dual diaphragm booster and a master cylinder from 1970- 1976 model falcon. It's pretty common stuff in other words, maybe your mustangs would provide a good unit to retrofit?
Ya get that on big jobs.
