Like Tree7Likes
Old 08-21-2012, 12:29 PM
rgnbull1227's Avatar
Cobra Make, Engine: Superformance SPF2271
Specifically-it will make more heat to reject than a hydraulic 428. It will never run cool for 'street use'. Also, depending how much cam it has it will idle around 1100 and not happily. It won't loaf along in traffic without a lot of temperament. It's not an LS Vette with AC. There is nothing to like below 3500RPM for your use. How much power did the builder show you it made?
A hydraulic roller top oiler will make excellent torque for what you want without temperament-you don't need side-oiling -why spend for it?
Builder said it made approx 550hp. Well, this was NOT what I wanted to hear but it seems this may not be the car for me. The sound of this engine was just music to my ears.
Cobra 3 - YouTube
Old 08-21-2012, 02:10 PM
Cobra 3 - YouTube
Tip for buying Cobras; don't accept what somebody 'said' it made. If you're spending $40-$100K on something, see documentation on the build and it's testing. Buy something that suits your use too.
Chas.
Old 08-21-2012, 03:03 PM
RodKnock's Avatar
The reason I am mentioning the 427 Nascar Tunnel port engine is that I am looking at a Car with that engine. Its got loads of work done to it and has approx 12:1 Compression. Has a ton of DOVE parts. Current owner adds a few gals of VP C16 fuel with hi test.
I've been in the car scene nearly all my life and I've never heard of "VP C16 fuel."
Dove parts? What happened to all the Ford Tunnelport parts?
Listen to Chas, he knows mostly what he's talking about. (just kidding)
As to what premium I would pay for a 427 vs any other engine in a BB Cobra that I was considering? The answer would be:
The cost to build and install my new 427 less the salvage value of the engine being pulled from between the fenders.
Old 08-21-2012, 03:08 PM
DAVID GAGNARD's Avatar
Cobra 3 - YouTube
Listen to the folks who have "been there,done that"......your talking about a high compression,very tempermental engine that will require a lot more than the average engine.....
For your stated purposes,if your dead set on a big block car,you'd be much better off with a nice stroked 390/428......
If you buy this car,I'll bet within a year you'll be looking to sell it......
DAVID GAGNARD
Old 08-21-2012, 03:57 PM
.. then you never heard of C12 and C14 either.
And I've NEVER been accused of knowing what I spoke about-even a little.
Chas.
Old 08-21-2012, 04:02 PM
RodKnock's Avatar
I'm guessing jet fuel, but who really cares. I'm sure Patrick will chime in next
Old 08-21-2012, 04:24 PM
VP C16 is here. Ive used this many times in my 300+HP Snowmobiles as well. Good fuel.
http://www.vpracingfuels.com/vp-drag-racing.html
Old 08-21-2012, 04:48 PM
I knew what it was... I was just thinking how much I would have had to carry in the trunk when I took that all day ride earlier this month in order to mix it with the fill-ups along the way. Not only is it not cheap, but it catches fire and explodes easily.
Old 08-21-2012, 05:11 PM
it is less flammable than regular gas! Expensive yes. Instead of running this in my turbo sleds, I switched over to meth injection. Much easier.
Old 08-21-2012, 05:25 PM
But what I was thinking is that the little trunk we have would have to be full of cans of what essentially is Sunoco 260. You know, the old "dial-a-pump" thing that Sunoco had. That would be a PITA, trust me....
Old 08-21-2012, 05:36 PM
Frank Messina's Avatar
It may not matter for your intended purpose, but you'll never be able to stray farther than 1/2 tankful of gas (you have to get home for another dose of C-whatever). While this engine combo sounds pretty exotic, this could become a giant PITA pretty quickly. Then again if you're only planning on keeping it for 2 months, disregard all of the above and plow forward. FWIW.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
Old 08-21-2012, 06:46 PM
rpatton3's Avatar
Maybe that is why Baskin-Robbins has thirty-one flavors!
Russell
  #33 (permalink)
Old 08-22-2012, 05:07 AM
undy's Avatar
Not to mention that you get get quite a bit more usable horsepower over and above the (reported) 550 with a semi-docile stroked FE... 482"+.
Too many toys?? never!
  #34 (permalink)
Old 08-22-2012, 06:49 AM
mdross1's Avatar
These guys are right about trying to run a car with an engine built like that.Once stuck a cam in a big block Chevelle after dialing it in sounded very menacing but oh so sweet.Up until about 4k rpm's it was a dog but once it hit the tires always started to melt.Trying to cruise through town was an absolute pain.Back then we were able to fuel up at Sunoco stations.Around here it is next to impossible to get a barrel of VP fuel.
  #35 (permalink)
Old 08-24-2012, 05:10 PM
dls141's Avatar
Cobra Make, Engine: LA Cobra / B&B 427 SO
Default Simple answer
It's a simple answer really IMO.
What does the emblem say on the side of the car slightly above and behind the front fender louvers?
Here's a hint: What SHOULD be under the hood of a 1969 big block Vette that says "427" on the hood scoop?
Again just my opinion. But then again I AM just a rank amateur.
