November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 09-18-2012, 10:03 AM
Club Cobra Member
Cobra Make, Engine: NAF 427
Default Washers for banjo fittings on calipers
Hi all. Any wisdom on what are the best crush washers to use on brake caliper banjo fittings?
Copper or aluminum?
Greg
Old 09-18-2012, 10:12 AM
Jerry Clayton's Avatar
copper
Old 09-18-2012, 10:35 AM
Club Cobra Member
Yeah, I had aluminum washers on but had a hard time stopping the leaks.
Copper it is.
Thanks
Greg
Old 09-18-2012, 12:50 PM
mickmate's Avatar
Make sure they are banjo washers (softer copper) and are sized to the banjo (metric or standard) thread size.
mickmate
http://www.actoncustom.com/
Old 09-19-2012, 11:31 AM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I've had good luck with the Earl's stat-o-seals. Search Results for stat-o-seal - SummitRacing.com
Old 09-20-2012, 07:49 AM
Club Cobra Member
Hi CJ428CJ. Have you used the Earl's stat-o-seals on brake line banjo fittings?
I thought about these but wondered about the brake fluid affect on the rubber and about the pressure.
Greg
Old 09-20-2012, 02:06 PM
CJ428CJ's Avatar
Yes. I had a slow brake fluid leak that I couldn't get to stop with regular copper crush washers. I switched to the stat-o-seals and that solved the problem. It's now been leak free for the last 8 or 9 years.
Chris
Old 09-21-2012, 08:36 AM
Club Cobra Member
Thanks Chris. I replaced the aluminum crush washers with copper and it seems to have done the trick. I'll order some stat-o-seals as a backup.
Greg
