2Likes
02-24-2013, 07:35 PM
VA
Cobra Make, Engine: Former Owner of both Superformance #2666 Roush 427IR and Superformance #1601 Ford Crate 460CI - 486 HP 510 ft\lbs TQ
Neutral
Smallest Enclosed Auto trailer that will accommodate a Cobra?
Hey Folks,
I am interested in what is the smallest enclosed auto hauler that can be used for a Cobra. I am kind of limited by the fact that my 4Runner will only haul 5k lbs. Went shopping the other day and have some questions. How the hell do you get out of the car once you have pulled it in? 7ft wide trailer has no wheel wells but is skinny but the 8.5 wide trailer has wheel wells inside. Not sure how I can pull the car into either and get out of it. Or not asphyxiate myself once pulling it inside the trailer. Interested in what brand and size you haul your Cobra in!
Thanks!
JB
GUMBALL!
02-24-2013, 08:25 PM
MO
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
A 16' trailer is about as small as you want length wise. Not sure if it would even fit in to a 14'. A couple of our club members have 16' trailers. One is 7' 6" wide, one is 8' 6" wide. The 7'6" wide one only fits a 289 slabside Cobra, and he has a floor winch to get it in. He doesn't drive it in. The 8' 6" wide one is wide enough to drive in. Mine is 8' 6" wide x 20' long. Plenty of room width wise to drive in. Once in, I don't open the door, I step out over it. I could open it, but not far enough to get out of without it hitting the fender wells. Just my experience.
02-24-2013, 08:27 PM
Cobra Make, Engine: Hurricane 427 Cobra #HM2008, Craft Performance 427w 600hp/600tq, TKO-600 close ratio, original Smiths gauges, lucas switches
Check out Serpent Express - HOME
Bob Worley
Hurricane HM-2008 build is done!! (for now....)
Craft Perfomance 427W / 600hp / 600tq - TKO600
I love it and I need it I bleed it ~ Yeah it's a wild hurricane ~ Alright, hold tight, I'm a highway star!!
02-25-2013, 03:08 AM
SC
Originally Posted by Bannon
Hey Folks,
Thanks!
JB
Regardless of what your towing capacity may be rated at, I would not tow an enclosed trailer with your vehicles. Safety reasons being the first one.
If you insist on a trailer for your Cobra though, you really only have one option and enclosed won't be it.
Trailex Home Page
Bill S.
02-25-2013, 04:49 AM
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
I agree with mrmustang. Safety must always be first. A vehicle may be able to pull, but stopping & controlling on the road are different issues. For example, A Tractor Trailer can really push a vehicle around when passing it at speed on the open highway & a windy day can really make it even worse. A tow vehicle should have the towing ability along with braking & controlling ability. It's not only for your safety but for the safety of everyone else on the road. You would feel horrible if someone got hurt & even worse if children were involved. I recommend a 3/4 ton pick-up as it has heavier running gear & larger brakes.
Just my .02
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
02-25-2013, 06:40 AM
KS
Cobra Make, Engine: jbl
i use a 20' enclosed and it imo would be the smallest i would go, leaves some room at the front for misc. like purple venom says, step over the door onto the fender sill and you are good to go. 16'er would work also i imagine but you might want to consider resale value.
i also have a winch in mine, makes loading easy. hook a tow strap to the roll bar and pull it into the trailer backwards, unloading is easier.
pulling loaded with my f250 truck i do get moved around on the highway by the big trucks, but if you go easy and don't drive like your are in a hurry to die you should be alright. enclosed is nice for overnighters, or storing stuff also. loaded my trailer is still under 5k lbs.
02-25-2013, 07:40 AM
Cobra Make, Engine: CSX2321
Loading backwards might not be the best idea if that does not provide the proper tongue weight. You want about 10% of the total weight of the load on the tongue. That can be hard to do with the weight of the engine behind the axles.
02-25-2013, 08:20 AM
KS
that is a good point, i did make that mistake once  . just have to make sure it is in far enough, or if tongue weight is a problem try the other way.
02-25-2013, 08:35 AM
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
My Serpent Express was towed (not by me) behind a GMC Envoy from Michigan to Houston,Texas. A good portion of the trip was with an ERA inside. I understand there were no problems on the trip.
Maybe the driver of the GMC will comment about his experiences on his trip.
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
02-25-2013, 08:40 AM
If the weight distribution is about 50/50 fore and aft then it is really the longer rear overhang that causes the balance issue when loading. IMHO. I load nose first.
02-25-2013, 08:54 AM
Even a 6" difference fore or aft of the car on the trailer can make a noticeable difference in tongue weight.
One element that may be overlooked by some is having the correct height receiver (drop) on the tow vehicle that allows the trailer to set level.
02-25-2013, 09:16 AM
x-treme trailers..all aluminum, i love mine....the side door lines up with the car door you can step out of the car and out of the trailer
Fred B
02-25-2013, 09:30 AM
Used the Peter Brock trailer for Amelia last year with CSX3021. Very light, rigid and easy to pull with 1500 rwd GMC. Claimed to be low drag so pulling was effortless, it was.
They are a little pricy though.....
02-25-2013, 09:54 AM
OH
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
I've got a 16x7 v-nose trailer that I tow with my 2001 Dodge Dakota. I'm very happy with it, and yes I DRIVE IT IN.
Pete
02-25-2013, 10:00 AM
Full Blown Member
I've got a Serpent Express on a Featherlite 3110 and I'm pretty happy with it.
It's very stable and has better suspension (Torsion) than the Trailex leaf springs, IMO.
rodneym
02-25-2013, 10:02 AM
Something simple I learned from Dennis Olthoff was to merely feel the tire temps when towing. The rear axle tires will run ever so slightly warmer than the front axle. And if the fronts are warmer, they are carrying more load and I would need to raise my hitch. The rears run slight warmer because the air flow to them is blocked by the front axle tires. Measuring the height of my frame to set the loaded distribution matched his advice perfectly. My Serpent Express is 14 feet. That is about as short as you can go. More is better.
02-25-2013, 11:29 AM
KS
nice sounding aluminum open trailer just came up for sale on the ffr forum, in illinois.
02-25-2013, 11:42 AM
Also trailer tire pressure is very important........I tow a 2800 pound race car on a 16 foot tantem open trailer,with my setup,if I have 32 or less psi in the trailer tires,it will sway like crazy from 55 mph on up,upping the air pressure to 36 to 38 psi and I have hit 80mph passing other vehicles and it will tow straight with no sway to it, tire temps are better at the higher psi in the trailer tires.......
another rule of thumb is to hook the trailer to the tow vehicle,on a level hard surface,measure the heigth of the trailer tongue at the hitch,then load your car, you want the tongue heigth to be about 1 to 1.5 inches lower than before the trailer was loaded,no matter what the load is....this will give you the approximate correct tongue weight, you may need to adjust slighty,but it'll get you in the ball park.......
DAVID GAGNARD
02-25-2013, 12:08 PM
Brock Trailer
