| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
3Likes
04-29-2013, 03:24 PM
Cobra Make, Engine: SPF#0760
Wash away now that the acid is neutralized.
They also have a battery mat for under a battery that us supposed to neutralize battery acid. Can't say either way since my battery on the Cobra has had no problems, but I do have that mat installed in the Porsche as a safety precaution.
Have fun,
SPFWiringDiagrams@Comcast.net
04-29-2013, 03:27 PM
Thank you guys for the great information. Will replace it.
Chas.
04-29-2013, 04:35 PM
PA
i do know that a properly installed muffler bearing can net you 50 more HP
i still remember the sea monkey ads in the back of magazines
Fred B
04-29-2013, 04:53 PM
BUT-you need a left-handed muffler wrench to install that bearing!
Chas.
04-29-2013, 06:21 PM
What have I started????
04-29-2013, 06:50 PM
PA
what? lol
Fred B
04-30-2013, 05:36 AM
SA
Cobra Make, Engine: CR Cobra 3169
Are both end of the battery case bowing out? Plates are sulphated. If you have any plates that are almost touching, they will create a resistance, especially when charging, therefore creating a localised heat, boiling the fluid.
i wotk for roadside service, and batteries fail for all sorts of reason. Some die instantly, some slowly. The one you have to watch out for, is the open circuit battery. It will destroy computers etc.
JD
04-30-2013, 07:33 AM
Thanks for the tips. No, sides seem normal. But it's going back today for warranty replacement.
Chas.
04-30-2013, 11:41 AM
A happy (for now  ) ending. Returned batt to Pep Boys and no questions asked, a brief test and a new one in my hand.
Tech determined that the cell nearest the neg terminal was crapped. I live and learn.
New one was manufactured in Dec. and shipped in Mar.
12.5 out of the box. 14.8 at 1500 and 14.2 at 600-all at 63F. Took a little bit of distilled to get to the split rings.
Will watch it for a while as paranoia never goes away.
Thanks to all.
Chas.
04-30-2013, 04:13 PM
Ill
Do you use a hydrometer to check the cells??????????
04-30-2013, 04:16 PM
NO Jerry-that's why I called for you expoits!
How does one do that?
Chas.
04-30-2013, 04:59 PM
Ill
I'll assume that this isn't another one of those funny lines---------
Battery charge is checked cell by cell with a hydrometer----fully charged will be 1.25 sp gr(Ithink) A battery that won't take a proper charge will show up with a low spgr which if is just in one or two cells indicates a defective battery-------
are you going to the GSL Model show in Salt Lake City next week?
04-30-2013, 05:17 PM
No Jerry-not joshing you.
I just looked up and learned you're referring to specific gravity. I don't think that's the test the store did. I think they started a load test and saw one cell out to lunch. In minutes the guy came out with a replacement, brand new, and I was happy. Still have a new 3 year warranty from Bosch.
I had been testing with my VOM and saw regular 12.5V. But two cells definitely had sulfate deposits.
Negative on the GSL-I'm in Long Island. Do wish I could meet you though. I'm the guy that sends you those cool links to your old FED. Where is Keeling these days?
Chas.
04-30-2013, 09:06 PM
Ill
John Keeling died of cancer back in 96 or 97---------
Have you seen the coverage on www.nhra.com-----dragster insider????????? 3 weeks now, probably 50-60 pics, stories from all sorts of people????????????
The Keeling & Clayton story continues
05-01-2013, 07:12 AM
Sad about John. Yes, I follow and enjoy every page. Miss those days.
Chas.
05-01-2013, 09:57 AM
PA
Chas.....long island? did we meet before?
have you gone to any long island cobra club events? ...like to Lebanon valley dragstrip
Fred B
05-01-2013, 11:14 AM
AR
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Blinker fluid
Originally Posted by tkb289
Chas,
If you wind up needing a new battery, some are made with a vent spout that you can connect to a drain hose. Should this happen again, the water / acid goes on the ground and not on the car.
Blas is right, get it tested. I do like the blinker fluid theory
Years ago, it was "muffler bearings" and nobody got that either. The sea monkey thing is priceless.
There were no atheists in the foxholes.
05-01-2013, 01:14 PM
Don't think so Fred. I was not a 'club joiner' and never 'showed' the car.
I occasionally met some owners at Nick's in West Babylon and some of those guys raced at Lebanon but infrequently.
I autocrossed at Tobay, drag raced at West Hampton and ran it at track school at Bridgehampton before it closed. The car has recently run a track day at Lime Rock in a charity event.
Mainly I terrorized the back roads here...
Chas.
