Old 05-05-2013, 07:50 PM
Default Superformance turn signals
My SPF 1698 turn signals stopped working today , anyone else had this issue ?
I have checked the usaul suspects , bulbs , fuses are OK
I did have the steering wheel swapped for a leather wrapped one but they were working Ok for the last couple of years with that mod
Any thoughts on what it could be
Old 05-05-2013, 08:25 PM
Cobrajames's Avatar
Cobra Make, Engine: SPF 2303, Titanium Silver, Roush 427 SR/TW, AED Carb, Firefly Sides, TKO 600
Have you checked your flasher in the fuse box area?
Old 05-05-2013, 09:20 PM
I have spf 1721 and the problem I had with mine was a broken wire at the turn signal switch. Fortunately it was a fairly easy repair.
Old 05-05-2013, 09:24 PM
spf645's Avatar
Cobra Make, Engine: Superformance, 351w
I agree, try flasher first. Pry it open if need be. File,(sand) the contacts. It's worked for me many times in the past. Nothing lost but time if this doesn't fix it.
And if it does, well as I'm finding out, money is going to be needed spent else where on car.
Old 05-06-2013, 04:54 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
The plastic cover on the flasher units has a tendency to get crushed in the spring clip that secures it to the drop-down fuse panel. Just replace the flasher unit. It’s about $7.00.
SPFWiringDiagrams@Comcast.net
Old 05-07-2013, 05:13 PM
I am having trouble locating the flasher unit , in my manual it says the fuse box should be under the the glove box but it is not it is under the steering wheel and I dont have a diagram showing me what unit is the flasher unit
Old 05-07-2013, 05:58 PM
Blas's Avatar
Rob,
You have an email with a photo that ID's the flasher unit
Blas
Old 05-07-2013, 10:19 PM
Blas
Thanks a lot , I fixed the problem it was a loose flasher unit
