Old 06-03-2013, 01:14 PM
cobra 53's Avatar
Cobra Make, Engine: NAF 289 Blue/White strips
Default HELP !!!!! Engine wil not STOP !!!!!
Hi folks,
After I started the engine (SPF 302 with MSD 6 ignition box) to drive a little after a longer time, I realized a big problem:
I tried to stop the engine. Turning the ignition key "off", the engine did not stop. Turning the battery cut out switch "off", the engine did not stop. Taking off the two keys, the engine did not stop. All gauges turned to "zero".
I finally stopped the engine using the 5th.
Putting in the keys to start the engine is not a problem, but stopping in an ordinary way with the keys is still not possible.
Do you have any good suggestions???
Thanks, Rico
Rico, NAF 289
Old 06-03-2013, 01:18 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
You have a run on condition caused by alternator feedback
Old 06-03-2013, 02:07 PM
cobra 53's Avatar
Thanks Bill. Can I find the failure in the alternator itself ?
Rico, NAF 289
Old 06-03-2013, 04:53 PM
Bill D's Avatar
Nota failure. The exciter is sending voltage back to the ignition circuit. You need to add a diode to the circuit to prevent this condition
